salguod
- Feb 16, 2019
- 0
- Hilliard, OH
- Ford
My 1995 Ranger 2.3L 5-speed will not start. I replaced the starter and it briefly solved the problem but it has returned.
When I replaced the starter I cut and spliced with heat shrink the last ~6" of the small wire going to the starter, as instructed with the starter.
Before the starter replacement and leading up to this failure I would get clicking and then it would crank and start. Now, when I turn the key I get a single click or clunk and that's it.
Battery measures 12.3 volts across the terminals. Jump starting with a jump pack did not help.
Both battery cable terminals have been replaced be the previous owner with crimp on terminals. I pulled each apart, cleaned them and reassembled them but there is no change. There's also an added ground cable that bolts to the firewall (see attachment).
My thinking is that I'm not getting enough current to the starter and I need to replace both battery cables, however it looks like at least the positive cable is not available. It looks like a specific cable with a large lead to the starter, I assume, and a smaller lead that does to a rubber block with two terminals on a fender mounted device that I'm not familiar with (see attachement). Looking more closely, it seems that the wire from the battery only connects to the bottom terminal of this device (relay?). If I want to replace this cable, can I run a 4 ga. cable from the battery to the starter and a secondary, smaller wire from the battery to this device? Rock auto seems to have the proper negative cable (https://bit.ly/2Oal9Hv), which I hope will replace both the negative cables in my truck. Does it look like the right cable?
Thanks for your help.
