1994 Explorer
Bruce
Southwest Missouri
4.0 SOHC
1994 Explorer, DPFE failure
I have a 1994 Explorer 4.0 and im going thru PDFE's about once a month or so..is there a cure for this (code 327) at least i have a 2 year warranty on it..lol buts its beginning to be a pain.:sad:
Thanks : Bruce
nitrofan1
Man without a Ranger
MTOTM Winner
19
Chattanooga, Tennessee
Subaru
EJ251
If you are going through DPFE's like that unless you are buying plain crap I'd say that's not the issue. A trouble code doesn't specify that exact part is bad most of the time. If the DPFE code comes up when I read it or just about any code it's time to get out a scanner. As an example a Snap-On scanner will show me all the ranges and specs on the sensors. Since the DPFE is a feedback sensor look at the EGR valve itself. I had a customer with similar issues. He was getting pissed on the 3rd DPFE and I suggested cleaning the EGR valve. Guess what? No more DPFE issue.
Course don't just stop at the EGR valve. Clean the mounting plate area as well. Clear the code and see if that will stop the issue.
nitrofan1
MTOTM Winner
19
Subaru
EJ251
I was just looking through my code book. There is no #327. I even tried #1327 and nothing. Pull the code again and post it.
Donnie strickland
From the service manual:
"DTC 327 indicates the Pressure Feedback EGR (PFE) / Differential Pressure Feedback EGR (DPFE) sensor signal is less than the Self-Test minimum value of 0.2 volt.
Possible causes:
Damaged PFE/DPFE sensor.
Open harness circuits.
Shorted harness circuits.
Damaged Powertrain Control Module (PCM)."
According to this it sounds like an electrical problem. Sorry, that's all I've got. My truck doesn't have EGR so I've never faced this.
