JunkCollector
- Dec 17, 2017
- Reaction score
- 1
- Location
- VA
- '85, '88, '91
- Make / Model
- B2, B2, Ranger
- My credo
- Local RBV "expert"
I bought a new rig recently after getting out of RBVs for a good while, and am looking into some key issues that it's throwing at me. I've ran several KOEO tests. I'm seeing a left O2 sensor "too lean" and "too rich" code, "EGR flow lower than expected" "fuel pump secondary circuit fault" and randomly MAF and TPS codes. It starts and runs, with a dead miss, so I'm unable to run KEOR tests. It will run very poorly unless idling or wide open, almost as if there's no fuel. If I kill the key when it's hot and start it back up, it'll run better for about a minute, then start the same thing again. I also believe there to be a slow leak at the fuel rail and through research I know for a fact that's causing at least some of it, but it seems sometimes the FPR will make up for it, and other times not.
I'm going to replace the O2 sensor and check into the fuel pump monitoring wire as a first step. Also need to figure out where a few evap hoses are supposed to lead. Is there anything else I could be missing that is causing these issues, something common that would make it act up? Fuel pump and filter are new, from previous owner. I know it's a bit early to make a thread without fixing the obvious issues, but I'm not looking to fight it for months on end with no outcome. Thanks guys!
PS here's the current codes in numbered form, pulled with a scanner
176
177
332
543
111 (system pass code I believe)
176
177
332
543
