1994 B4000 4.0
Walksnotruns22
23
Washington
Mazda B4000
The pulled headliner cost $12.00. I found a back window too. It was just $35.00. Our U-Pull yards have Facebook pages so I follow them and watch.
You have a nice truck. Good luck.
Thank you
Walksnotruns22
23
Washington
Mazda B4000
I pulled the headliner and there is no plastic between it and the roof.
gaz
671
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (1½" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 33"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
I just dropped the fuel tank on a 94 Explorer (same set up as 94 Ranger), it was super simple. With a night or 2 of penetration oil at work, all the large fasteners came out with little or no fight against the impact driver. I used a transmission jack to support and lower the plastic tank.
Of all the fuel tanks I've ever dropped, this was by far the simplest. If you are set on removing the bed for access, I highly recommend making an access door for future fuel tank system work.
Walksnotruns22
23
Washington
Mazda B4000
I can see dropping it on an explorer but for a truck wouldn't it be easier to just remove the 6 bolts in bed and 3 at fuel filling neck, then just raise and move bed a little to access the tank? I saw someone on YouTube do it that way. I prefer easiest way since I am a one man wrecking machine. Lol
8,372
Dropping the tank is easy for sure, putting it back in can be the hard part
In a shop with a lift and transmission jack its OK, in the driveway......................not so much, lol
In a Ranger tilting up the bed or sliding it back is the way to go, IMO
Walksnotruns22
23
Washington
Mazda B4000
Makes sense. I don't have any of that fancy stuff. Just me in a gravel driver and half a garage.
Northidahotrailblazer
463
Northern Idaho
Solid Axle Swap 4x4
8 inches
37"
Hello, I'm up in Sandpoint area. Lived in Genesee for a year. :cool:
Walksnotruns22
23
Washington
Mazda B4000
Do you think a person can remove the bed by themselves or will it take two people?
8,372
Easier with two, but for sure doable with one, as far as just sliding it back a few feet
Walksnotruns22
23
Washington
Mazda B4000
Anyone know if the 93-97 ranger extended cab headline would fit a 94 Mazda b4000 extended cab truck. I know they are pretty much the same truck but want to make sure.
Walksnotruns22
23
Washington
Mazda B4000
Ok. Thank you. I will try to do it the safe way of two at first but If I can't find someone then so be it.
8,372
You will be surprised at the weight of the bed, or the lack of weight of the bed, lol
Tailgate is probably 20% of the weight, and you can take that off first, no bolts just take off the straps, and one hinge is slotted, line up the slot and lift out the tail gate
You can also remove front 4 bolts then loosen the 2 rear bolts in the bed, leave them almost all the way unscrewed
Then you can then tilt the front of the bed up and use 2x4 or other post to hold it up
But this depends on what rear bumper setup you have, and its for two people
Sliding the bed back is for one person, or two, just go from side to side lifting and sliding, so wiggle the bed back
Walksnotruns22
23
Washington
Mazda B4000
I will take the tailgate off now that you said that. I wouldn't have never thought about that.
Walksnotruns22
23
Washington
Mazda B4000
So I might have made a mistake and need opinions.
I just went up and grabbed a new back window from a junkyard (2.5 hours away, closest one) and got home to realize that the window doesn't have the bolt holes that the current back window has.
It came out of a 94 ranger. I haven't took the window out of the mazda truck yet, do the bolts come off the other window?
What should I do?
