1994 B4000 4.0
Walksnotruns22
21
Lewiston Idaho
Mazda B4000
Welcome to the forum
4.0l OHV(1990-2000) is a very reliable engine, but DO NOT let it over heat, pull over immediately and let it cool off or you WILL crack a head
car-part.com this is a good place to look for local(zipcode) used parts
But you can get new rear glass
Used rear window from a 1993 thru 2011 Extended cab Ranger/B-series will work, they bolt in, later years may need 2 extra holes drilled, in truck side, not a big deal
1998-2011 regular cab rear windows will also work, they have bolt in rear windows
(1986-1992 extended cab also fit, if memory serves)
Solid or slider are interchangeable, so use what you want
1997 and earlier regular cab rear windows won't work, they didn't bolt in, they used a gasket to hold them in place
So I have a question and I don't know if I have been misinformed. I still have the window that I got last month that is the wrong window but Spalding (the junk yard) is adamant that it was right. They said they pulled it out of a 95 Ford Ranger Super Cab but the window don't have bolts to be able to install. I noticed that they also have a 2000 Ranger Extended Cab with a sliding window, would that window be bolted in? The guy on the phone acted like I was an idiot for asking if it bolts in.
The yard is a few hours from home so don't want to just make a useless drive up there again.
Thank in Advance,
7,784
Regular cabs up thru 1997 don't bolt in, 1998 and up regular cabs do bolt in
All extended cabs bolt in
All use the same size rear window, and 1998 and up regular cab used this same size as well
You have a 1994 B4000 but don't say if its regular cab or extended cab
So can't tell you what you need
If window you got came from a extended cab(supercab) then it bolts in, if you don't see the studs then it was mislabelled on their end, on what it came from, it happens
If you have an extended cab then the 2000 slider will fit and bolt in, if you have a regular cab then it won't
Walksnotruns22
21
Lewiston Idaho
Mazda B4000
Ok, thank you very much.
I have an extended cab (cab plus).
I am assuming that they labeled it wrong but they are adamant they did not.
I guess I will call them back tomorrow and have them hold it for me. Maybe ask that when they remove it from truck make sure that it is bolt in and if not to call me.
Thanks again.
Walksnotruns22
21
Lewiston Idaho
Mazda B4000
So I finally took the other window (boltless) back to the junk yard to get my money back. Told them they gave me wrong one, lady that was helping me look at the receipt and the window and called her co worker and idiot. She also found me one that, for some reason, they have in there system as a single cab 1994 B4000 when it clearly is cab plus. They let me go out in the yard and the guy helping me torn it out right there for me. Also got my passenger side window motor with regulator and whole assembly. Only cost me an extra 30 bucks to get the new window and motor. I know I could have saved more money doing it myself but pros and cons. Do it myself in 100° weather in the middle of a junkyard to save 50 bucks or just go next door in the ac building and pay for someone else to do it and give it to me an hr later. I like the second option.
