1994 4x4 radius arm bushings
8,372
Was hoping the cross frame bracket was bolted on, and when I first looked I saw 2 bolts on lower frame rail but then 2 rivets on the side of frame................
Bummer
Any reason I shouldn't grind off the 2 rivets and replace them with bolts?
I can't think of any reason but......................
Other Rangers I have done were all bolted on no rivets
gaz
672
Wa, Bremerton 98310
Ranger 5" (1½" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 33"/3:73LS
@Ron D ,
I've done 4 RBV suspension lifts, all had rivits from the factory except the 88/89 High rider Ranger (I forget which year it was).
The only reason I can come up with to remove the factory rivits other than to install aftermarket radius arms or a lift is to preserve or repair the bracket and the metal underneath.
rusty ol ranger
2.9 Mafia-Don
7,641
Michigan
177 CID
Bummer
Ive replaced 2wd brackets on my ranger anf 250 both and used grade 8's to replace the rivets. Youll be fine
8,372
Trying to avoid having to pull out the long, rusted in place, bolt on the beam
ericbphoto
Overlander in development
16,730
Wellford, SC
6"
Perfectly fine. Replace the rivets with bolts same size as the holes. I often use grade 8 fine thread with nylock nuts and heavy flat washers.
Bgunner
1,095
Western Mass.
Ford/Ranger XLT
225/70/R15
When I replaced my radius arm bushings I ground the rivet heads off and took the rest of the rivet with me as a size indicator to get the grade 8 bolts. I haven't had any movement or issues doing them this way.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
where i live.
if you dont remove all of the rivots on every frame k member and section... and replace them with bolts......so you can take it all apart and clean and paint it periodically....your not going to drive it for 33 winters.
