1994 4x4 Axle shaft Problem
94Guy
Neenah
Ford Ranger XL
Hello everyone! I bought a 1994 Ford Ranger XL 2.3L manual over Easter and I'm trying to get everything to work. The one major issue is the 4x4. The switch was not working so I bypassed it by turning the T-case rod to 4hi and putting the shift motor back on. It works but for some reason the passanger axle can be push back out of the manul hub. Like I can push it almost to where it goes back into the knuckle. It still grabs on the locker but barley. There no broken parts on the axle and I can hear the snap ring holding it In the diff but I'm wonding what keeps the axle in the hub or what prevents it from walking backwards toward the diff?
8,372
94Guy
Neenah
Ford Ranger XL
8,372
There should be a c-clip on the axle inside the locking hub cover that holds the axle out
Seen in this auto to manual hub conversion: https://www.therangerstation.com/tech_library/howto_hubswap.shtml
There are two axle shafts(really 4, lol) on the passenger side, a snap ring may be missing where the axles meet allowing the movement, there would be some play but reads like more than usual
Diagram here shows the 2 axles(75 and 68), page 2: https://www.therangerstation.com/tech_library/pdf_documents/Dana_Ford_35.pdf
94Guy
Neenah
Ford Ranger XL
Okay great! This is what I needed! that C Clip is gone that's why is keeps walking out. I have a few more questions.
1. I also can't get the inner bearing out of the rotor. Does it need to be pressed?
2. It seems that there is a lot of rust on the spindle. It has a lot of pitting. I looked around and it seems its really hard to find a new spindle for this gen of ranger. If anyone has some part # or places I could look?
8,372
Both inner and outer bearing races can be removed, no press is needed to remove or install
Never looked for a spindle for my 1994 but they would be expensive, if available
Should be some numbers in above diagram link
