1988 Ranger 289 swap questions
88-ranger
I have a 1988 Ranger with a 2.9l and a 6inch skyjacer lift with 33's. I just bought a 1965 ford 289. My question is what all do I need to do the swap besides (engine mounts,headers,oil filter relocator,and an oil pan) What type of tranny should I use? Can I use the stock t-case? Any info will help.
snoranger
Professional money waster
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
IIRC 65 was a change-over year. Is it a 5 bolt or 6 bolt pattern block?
88-ranger
It's a six bolt
JoeyB
Everywhere but right now Asheville, NC
302 / TF heads & cam, Harland Sharp rockers, Intake, Holley Carb, MSD, 5 speed with Hurst Shifter
Here is a good link to get you started down the road on a V8 swap.:icon_thumby:
http://www.therangerstation.com/tech_library/V8Conversions.html
A few other things to add to your list would be driveshafts (shorten and lengthen), radiator, fuel regulator (if going from EFI to carb), trany (manual or auto) and the list could get a lot longer depending on what you want to achieve with your build. You can use the stock t-case (I am) unless you plan on putting a lot of horses under the hood and use the truck as a 4x4 rig only. I have had no problems but the amount of off road I do is very small. Have fun doing your build.:icon_cheers:
sohc86-06
April 2011 STOTM Winner
MTOTM Winner
1986 2wd ranger
ford ranger spo
hey welcome to the site be sure to search the fourums lots of good info on v8 swaps
85_Ranger4x4
17,833
SW Iowa
You will need the elusive dipstick in pan oilpan, not the one without the dipstick that all but grows on trees.
88-ranger
Are there any good aftermarket oil pans that would work good and have a dipstick? Also what type of tranny would you suggest?
snoranger
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Spectra part #FP11C.
Teddyzee
December 2011 STOTM Winner
MTOTM Winner
15
Nova Scotia Canada
5.0L HO, GT40 heads, GT40 intake, 65mm TB, 1.7rr, Tri-Y headers, dual 2.5" exhaust, Flowmaster muffl
You can get the pans most anywhere.
One vehicle they were originally found on was the 1979 Mustang.
You can't post a link from napa, but p/n STP FP11C is one from there ($119)
$81 at rockauto.
Teddyzee
MTOTM Winner
15
Nova Scotia Canada
Good timing ;)
88-ranger
What vehicles came with a c4 transmission that would be a match for my 289?
