1987 Ford Bronco II Can't get Fuel
johndough
11
Virginia
Ford Ranger XLT
I bought a 1987 Bronco II that was sitting for close to ten years. I replaced in tank pump, high pressure pump, fuel filter above high pressure pump, fuel pressure regulator, and bypassed the inertia switch. I cannot get fuel pressure. What can y'all recommend?? I'm close to just sending it to the local mechanic but I'd really rather save money and fix it on my own. Any suggestions at all?
rusty ol ranger
2.9 Mafia-Don
7,578
Michigan
177 CID
Is the intank pump pumping?
lil_Blue_Ford
6,169
Butler, PA, USSA
4.9L
Check to make sure you don’t have any blown fuses and check the fuel pump relay under the hood. Make sure both pumps kick on for the priming cycle when you turn the key on. Check to make sure you’re getting 12v at the pumps if it’s not cycling. It is possible to get a bad pump out of the box too. It is a pain to do all of the testing, I’ve been down this road before.
alwaysFlOoReD
5,118
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Ive had multple vehicles with bad conections at the high pressure pump. Check to make sure that the spade connectors arent loose.
They are inside a rubber boot right on the pump.
gaz
666
Wa, Bremerton 98310
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
johndough,
First, does it have correct pressure on the fuel rail? If yes, does it maintain pressure overnight?
Since you have all those new pieces, hopefully tested, prior to installation and you have bypassed the inertia switch, is it an auto or manual transmission. Check the clutch position sensor on a manual or the neutral sensing sensor with an automatic.
The clutch position sensor can be bypassed to troubleshoot, I suspect the same can be accomplished with the neutral sensor.
rusty ol ranger
2.9 Mafia-Don
7,578
Michigan
177 CID
johndough,
The safety switches shouldnt keep it from obtaining fuel pressure.
If both pumps are running, nothings clogged, kinked or massivily leaking, there is no reason you shouldnt have pressure at the rail.
Im assuming you have actually checked for fuel pressure at the rail valve with a gauge right? Not just battleing a no start and assuming its fuel?
johndough
11
Virginia
Ford Ranger XLT
johndough,
0 psi pressure at fuel rail. and it’s a manual transmission. how do i check the clutch position sensor?
johndough
11
Virginia
Ford Ranger XLT
yes your right. i’ve checked with a gauge at the fuel rail valve. 0psi.
johndough
11
Virginia
Ford Ranger XLT
those are all good, appreciate it though man.
rusty ol ranger
2.9 Mafia-Don
7,578
Michigan
177 CID
Follow the fuel line from the tank up the driverside frame rail, youll see a little black canister looking thing. Pull the line off that run back to the tank and turn the key on, see if fuel pumps out.
Some even had a filter in the canister, that could also be plugged
lil_Blue_Ford
6,169
Butler, PA, USSA
4.9L
Forgot about that. Yeah, my 88 has one of those between the fuel tank and the high pressure pump and the ”normal” fuel filter up between the high pressure pump and the engine.
if both pumps are kicking on and you have 0 psi at the rail, there’s either a major leak, major blockage, or a pump is failing to pump. If the pumps are not kicking on, you either have a bad pump or a wiring fault. I’ve always started with checking to see if I have 12v at the pump after verifying the fuses are good and swapping the fuel pump relay with a spare I keep on hand. Sometimes I jump the inertia switch. If there’s not 12v at the pumps at that point, there’s probably a bad fuseable link or broken wire somewhere.
johndough
11
Virginia
Ford Ranger XLT
will do. i’ve tried messing with that canister and i could never get the cap off of it, any tips on how to get the cap off?
rusty ol ranger
2.9 Mafia-Don
7,578
Michigan
177 CID
Pull it off the frame and a big pair of channel locks....or oil filter wrench if its not to hard to get apart. Be careful with it though.
The cap just spins off kinda like a oil filter
johndough
11
Virginia
Ford Ranger XLT
actually now that i’m thinking about it, that shouldn’t be my problem. i bypassed that canister so that can’t be part of my problem.
