beerhunter
- Aug 21, 2017
- 22
- Ford Ranger
- Engine Type
- 2.9 V6
- 2WD / 4WD
- 4WD
Hi good people.
As per the title, 2nd gear is stiff when cold. It is only that gear, and only for a very short distance until (presumably) there is some heat in there. I live in an urban area, and by the time I have stopped and pulled away from 2 or 3 junctions the problem is gone.
I recently changed the clutch, but that was (a) very drawn-out, and (b) during a heatwave, so I honestly can't remember if this was a problem before then. I topped up the gearbox oil after the clutch change, with the standard stinky gear oil. The clutch fluid level is fine. In all other respects, the trans works fine, with no issues in any other gear.
Given that it is only when cold, I wonder if it would benefit from a thinner oil? Or is this one of those quirks one must live with when driving older vehicles?
Or have I stuffed something up???
Many thanks!
Many thanks!
