1962 Evinruide Starflite II 75hp V4 2 stroke....
rusty ol ranger
2.9 Mafia-Don
7,494
Michigan
177 CID
I have one of these mounted on a 1960 Glassmagic 15ft "Siren" boat.
The lower unit got water intrusion (assuming since the oil is milky) and i wanna tear it apart and fix what needs fixed. Since the boat is nice, and that ol evinrude is a runnin SOB.
Either way, how complicated is the lower unit on these? I watched a youtube video and it seemed pretty simple. I dont wanna repower it due to other 75-80hp USED engines going in the 900-1000dollar range, and no local boat shop will touch it.
Am i opening a can of worms or should it be a pretty straightforward deal?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I'd make sure you can still get the seals and other parts before you do anything. I've never dealt with anything that old but I've rebuilt the lower units on both my 86 evinrudes and they were not at all difficult.
rusty ol ranger
2.9 Mafia-Don
7,494
Michigan
177 CID
I already checked on parts, most stuff seems to be pretty readily available as it seems evinrude ran basically the same lower unit from 59/60 clear up till like 77.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Expect to replace gears. Take your time and be gentle because the housings are not incredibly strong. Easy to strip or crack the housing if you go gorilla on it. Other than that... it's just like a tiny little differential with a water and oil pump in it.
rusty ol ranger
2.9 Mafia-Don
7,494
Michigan
177 CID
I gotta double check my model number but it looks like 90% of it is available. Pricey. But available.
Ill see what kinda shape everything is in but it still operated flawlessly.
good thing you told be about finesse on the cover lol
ford4wd08
510
Alcoa, TN
2.8 V6
There is a guy on bbcboards.net that is a OMC gearcase legend.
He is located in TN, I believe his username is gearcaseman
I would join over there and drop him a PM, I can almost guarantee he can help you with the case.
He might even let you ship it to him to rebuild and send it back.
85_Ranger4x4
17,833
SW Iowa
Go longtail, you know you want to.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I see tons of them on shows in south America but only seen one once in my life in person. It was a small motorcycle engine. I guess the big selling point is, they are cheap to put together with whatever is laying around. Especially great in third world countries. But here if you want swamp power you go jet drive or fan.
ExploreNW
131
Mead, WA
Harbor freight motor, couple sizes of steel pipe, some hose, square stock, and a propeller... No vintage parts needed :unsure:
Bearings for your Evinrude will be harder to find but probably also need to be replaced. West Marine has a marine RTV that works pretty well where gaskets can't be found. A Craigslist parts motor could be a good idea. Don't forget to swap your points & condenser while you have the cowl off even if they're good. Those old 2 smokes still have years of good times on the water left in them
