RickSTL
- Dec 30, 2020
- 10
- St. Louis, MO
- Ford Ranger XL
Has anyone swapped an 09 rear drum factory set up to factory rear discs and maintained functional ABS? The truck currently has a 7.5 rear end. It is my understanding Ford went exclusively to rear discs in 2010.
I would expect to change out brake hoses and lines at the new calipers and new emergency brake connections. Are there any other hardware changes needed such as the proportioning valve? Does the ECU need to be modified to accommodate the swap to discs?
Thank you for any information you can provide.
