Wheel bearings are done. The seal on the inside was egg shaped on the drivers side allowing dirt and water in. The passenger side had Chinese bearings in it that still looked pretty good. Completely not my wife’s fault, just timing. New Chinese bearings and National seals and its smooth sailing. I’m going to replace the bearings in the spring when I do the entire front end so quality wasn’t a major issue at this time. I can order any SKF bearing or seal through work for dirt cheap so that’s the plan.
I hung the exhaust back up. The nut on my home brew threaded rod hanger came off so that was an easy fix. Nyloc nut and away we go.
I noticed while I was under the truck that the rear pinion seal was leaking pretty profusely so that got changed as well. Surprisingly the companion flange nut came off without a fight. 230,000 miles in Wisconsin winters/salt. The lips of the seal were worn pretty flat and it looked as if though the third lip of the factory seal that rides on the plastic seal guard was the only thing holding the fluid in. My last trip the the UP surely did it in. Lots of sandy clay and water. I installed another National seal there. We’ll see how it holds up.
I also got a couple tires to replace the two badly worn BFG M/T’s. I wanted to go to a 33” tire but this time of year sucks for spare cash and we need the truck for commuting the 27 miles into town for work in winter. My birthday, my wife’s birthday and our wedding anniversary are spread out through November and we always host Thanksgiving for both of our families. So I picked up a couple 32x11.50 Mastercraft Courser MXT’s to get the truck ready for snow.
I mounted them myself and they’re balanced with air soft bb’s. $325 out the door.
