RangerSVT
Oct 09 OTOTM
ASE Certified Tech
Boosted (Not Stock)
- Mar 15, 2009
I knew some rangers had steel, others aluminum, but didn't know the year break. But I have a sport trac sitting in the yard waiting for shop time, and I know it has a steelie, thats why I was gonna use that...I know the Ranger also had single pieces steelies up until '01(roughly). I got one from CeeGee's and it's a steel driveshaft out of a 2001 Ranger.
Chad, give me a call when your ready, I'll be glad to swing by and give you a handAll those goodys under the tarp......are about to find a hiding place at a friends shop to under go prep work without the prying eyes of the wife...![]()
98-2000 or 2001 Ranger had the steel shafts, as i'm rocking one in the ranger. I think it is 2001 when they went to alum but im not sure...
The steel ranger shaft is larger in Dia. Then the 2 piece offerend in the Ext cabs. But smaller then the alum shafts in the ranger.
Also, have you added Belltech shackles to your ride yet SVT? if not, that will rid you of the factory block, and let you run only the 1 block rather then 2.
Thats what i did for my lift kit, it called for double blocks, i went explo springs belltech shackles, and a single 3'' block to match 6'' of lift up front.
Hope that helps
I do know that the one piece steel is larger in diameter than the two piece, which is great cause that means it is a stronger shaft...I haven't done the 6400 shackle yet, and its in the plans but I should have done it a while ago, just keep putting it off...I'm waiting til I do my 63 swap, but I'm not using stock springs, I'm going with a lifted pack, preferably from Skyjacker. I currently have a ranger and exploder combo 6 leaf pack, which gave me about 4 inches or so of lift. At the time it didn't help my flexability, but it greatly enhanced my trailer towing capability, which at the time I was doing a lot of... My plans are to go with a lifted 63 and rid of all blocks altogether...I found a shaft on Ebay for $65 shipped, I'm waiting for the seller to respond if its steel or aluminum so the G/F can get me another X-mas present
SVT
