Chester Replacement
one more pic
Chester Replacement
Found some pics in a photo album.....
Chester Replacement
Chester Replacement
Chester Replacement
Chester Replacement
Chester Replacement
Chester Replacement
Chester Replacement
Chester Replacement
Man that thing looks good on 36's :thumb:
Well on the way to the Sundowner BB/BS ride something in my clutch decided to let go. Well i finally got it a part and found that the throw out bearing locked up and over heated the slave cylinder.
Chester Replacement
Chester Replacement
The clutch didn't like rocks and 36's with 3.73s.
Chester Replacement
Chester Replacement
Chester Replacement
The 5 speed is getting replaced by a C5 auto.
i got the C5 installed and the cross member moved up.
Chester Replacement
I had to move the cross member because the C5 is 3" shorter than the M5ORD-1 or A4ld.
Chester Replacement
Got C5 installed the rest of the way.
Ran into a few problems though. The T-case shifter needs to be modified.
Chester Replacement
I ordered a B&M Z-gate shifter and got it installed.
Chester Replacement
Chester Replacement
One other problem was when i tried to install the dip stick and the heater/ A/C box was in the way so i'm going have to get a now a/c box
Chester Replacement
Chester Replacement
The rear drive shaft was lengthen 6.5" and i still have to shorten the front one. There is something wrong in the valve body so i have to pull it ang get it fixed.
Chester Replacement
Chester Replacement
Chester Replacement
Chester Replacement
Chester Replacement
lookin good,:icon_thumby::icon_welder::icon_hornsup:
sweet ride,look foward to seeing more of this build!
Still having problems with the valve body so i ordered a TCI StreetFighter for the C4.
Got the valve body today.
Chester Replacement
Chester Replacement
Got it installed but i need to pick up a different filter before i put the pan back on
I just that i should up date. I got the trans finished up and had problems like losing all forward gears and slipping reverse. So the rig sat since October, and i ended buying a house so the truck got put on the back burner. I finally got around to removing the trans and took it to a shop. They said that every thing that the first guy that rebuilt the trans did every thing wrong.
I got the trans back and installed, shortened the front drive shaft, and finally got to drive it. The TCI valve body rocks, i can hold 1st and 2nd gear as long as i want.
Glad your ranger is up and running again. Your's is one of my favorites. Though it is no chester.
ok im sure i missed somethin, what the hell happened to the awesome truck named CHESTER?
Upcoming TRS Events
Featured Ranger Based Vehicle
