ForOffRoadDriving
haha, no the cardboard was just a cheap way to make sure i didnt make the box too big the first time. now that its all bolted in it looks like i could have made it and inch or two deeper to get more air space. ive got more pictures of what i got done today, mostly just mounting the subs in the boxes, but the holes are real close to the basket of the sub that i had to use rivet nuts and 8-32 slot head bolts to secure them in. as for mounting my power distribution, it will go to the right of the amp on the drivers side, i glued an extra piece of wood to the back wall (youll have to look close to see it) and i plan on popping the cables out from behind the rear panel, into the block, and then right back under the panel. the ground cables are running to the studs that i put in the floor with nylon lock nuts securing them. im going to take my multimeter and check for resistance between the ground cable at the amp and the ground post on the battery to see if ive got good enough ground. im happy with how its looking so far and i really havent lost any space (my jack and wheel chocks still fit inside the cubby holes behind the speaker boxes). TTI shipped my parts today, so i should see them by friday. now i need to focus on coming up with a plan for running the speaker wires from the doors to the amps. heres the rest of the pics:
