Update on my 88 Ranger SAS
update, zf 5-speed tranny, np205, twin shifters from JBfab, 302, workin on crossmembers
also just got Summit fuel cell, lines, holley elec pump, reg, MSD 6AL box, and more Ballistic stuff for crossmembers
We think alike. That's the same swap that's in the future for me. What I'm really interested in is how the ZF and 205 fit with the cab on.
I don't care what anyone says about the stack. That is badass. The only thing that could make it better is a pair.
Sweet build up ya got there. :icon_hornsup:
Brendan, your just gonna have to wait til I do the cummins swap for dual stacks, unless somone beats me to it.....:thefinger:
-andrew
-andrew
I've seen duals done on a sweet 460 (?) powered ranger. I'm pretty sure it was orange or red.
I've looked into stacks, and those buggers are expensive. If a guy could find a set cheap from a semi wrecker or something, that would be the way to go.
yea im not sure if im using the stack yet, i got it free from work.
im going to have to cut the whole center out of my floor to fit the zf and 205 cuz i raised them up so underneeth the frame would be all flat for a good skidplate to protect all that expensive stuff.
the center section of my floor im going to make removable to i can get to my tranny and case and all the lines im running under it easy
Well, that is one kickass build ya got there, I'd love to swap all my narrow SAS stuff under a first gen when I swap to FW's later on. I've got a few sets of stacks at work I can use, so they're cheap to me, lol.
-andrew
the build is lookin badass keep us updated...that is the way it's supposed to be lifted and a badass drivetrain to match you just made my day.
Use the stack except put it on the passenger side, single turnouts look badass.
rear side of crossmember done, .188 wall 1.5x1.5 square tube. ballistic fab poly ends/sleeves
what do you think of that design? its kinda hard to tell but as i build it you will see
the NP205 Pto cover mount out of .25 plate and 45* mounts .375 thick
i have a solidworks file of it if anyone needs it (or you could just trace over the stock plate i just felt like making it up :D )
Looks like a VERY strong design.
Will you be required to run a body lift for clearance?
mabey, i didnt really want to... i was planning on chopping up the floor and running tube across the sides to mount seets and new floor but i may have to do a slight lift
