byrons "ranger#1" 4x4 long travel build up
thats pretty narley for just an angle grinder dam
if it cuts steel, what did ya think it would do to skin.......
l8r, John
l8r, John
that is what the teacher says about the boring machine , it spins at high speed and takes steel off cylinder walls , it doesnt care wether it is cutting steel or skin
I've had a cutting wheel bind while I was cutting some angle iron for a flatbed and it just took off, slammed my foot and cut through my boot a little bit, nothing a guard could have done about that except have prevented me from actually cutting the angle iron. Guards are nice though, just sometimes you cant cut things with them on. I have it on whenever possible though for sure!
So where's the pics of the radius arms?
updates iv so busy with the new job at a new local fab shop that iv bin waayyy to busy but i ordered dom and it came too work today all 19 feet of it but until then i have some pix for you copiers out there =] and just remember all this is being done with an angle grinder so im trying my best
A.J. dont worrie i havent forgot about you man they should be being shiped mid week next week
hey ranger your lookin good thats what i want to do to my d35 when i pull it out of the bII, and for your adjustable coil bucket look at ballistic fab they make a bitchin lookin set that is pretty light on the wallet too
yea i have seen the balastic one and now i think im going to go coilover its going to be way cheaper than coil and shock
yeay updates for alll u megga travel junkies
ok well i started the truss
finished the truss on the back side of the passenger side beam and if anyone acuses me of stich welding or trigger welding ima going to bust some ballz
I wish work wouldn't filter the pics on the net...
ranger#1 are you using a 110 machine to weld everything?
i have the same lincoln machine but wouldnt dare to weld something that thick with it. i just use it as a sheet metal welder.
i break out the big 220 machine for something that thick.
and your welds look good. maybe slow the feed down a little. and clean the metal a little better, and it would be perfect.
but keep going man. it looks great.
the 110 works good up to 1/8 after that its miller 210 all the way home
