Project El Taco...1990 BII
DAMNIT! Ok.....I was really wanting to buy that engine..but never contacted him because he thought his stuff was GOLDEN!! lol. Glad engine and trans went to a good home!! I look forward to following this build.
Working on it, trying to raise some $$ for the project.
Got some changes im going to make to it, I havent given up, ill get some updates as soon as I have anything substantial to post.
woo, been a while, anything new going on with the project yet?
BUMP for an awesome build.
Alright guys, little update.
I have the B2 sitting on all four wheels again. I had to source a D35 which I got from the JY, and I had to buy a new radius arm crossmember, rockauto sells them new fairly cheap.
I did the explorer rear leaf spring swap w/o the overloads, and it sits a little more than stockish with 30x9.5 Maxxis Bighorns, Id say there might have been a 1-2" lift, its hard to tell since I never measured with the stock springs. I was more after the stiffer ride over the lift.
The front D35 is out of a 93 explorer and Im using the front coils. With no engine the thing sits sky high in the front, but I assume it will all change when the SOHC is in there.
Today I grabbed the injector harness from a 90 4.0 ranger at the JY, it was different than the 93? injector harness that I was planning on using. The connector to the main harness is square instead of round like the 90 harness. The computer was gone out of the 90 ranger, but I lucked out and found a Navajo with a 90 computer in it.
Next project is to run the 4.0 main harness and set the SOHC in for good.
I get some pics up tomorrow.
Here is some pics, I pretty much got the wiring harness in today.
I just read all of this and wow this is great. I saw that you were going to put a solid axle under it and said yes, and then when you said D35 i cried.
I put a TBI on my 2.8 and it runs great, but I can only imagne how great that broncho II is going to drive with that engine.
Keep up the good work.
Yeah, I lost my job and couldnt continue the solid axle I was building. I have to get my shop in order for my new business, so a D35 went back in and I have been working on it everyday for about a week. I wanna have it running very soon.
im gathering parts to do the same thing to a 84 ranger. pulling motor out of a 01 ranger.not shure if i will us a older 4.0 wirring harness or the one out of the 01. :dunno: i will keep and eye on this build.
that sucks man, hopefully you didn't spend too much on the replacement D35. I haven't even done anything with the one you sold me yet. so what are you gonna do out of the shop, machine and fab work? you could make some $$$ modding volvo heads for 2.3Ls and making brackets like the one you made for the r1HD to fit a manual t case.
na, I just got one from PAP, it wasnt too bad. Money is not really an issue at the moment, its mainly that fab equipment I had access to at my old work, thats why I didnt finish the axle. Im working on getting my shop setup with some cool stuff, I just bought a lathe today, and I have a milling machine already. Im working on getting a tig welder here within a couple of weeks. .Things are coming together, I just gotta get the BII running, movable and out of my way
I have plenty of ideas for stuff going through my head right now, I think Ill do fine on my own. After 8 years of working to make somebody else money, im a little burnt out on it, its my turn to make all the money for myself.
nice build im pumped for it runnin very cool. you should draw up some diagrams showin how to do the wiring. and get more pics. cause we love those. haha
Well I have been meaning to do an update for awhile.
Im really close to finishing it, well not finishing it, but getting it driveable.
All the suspension is in, explorer rear springs, explorer D35 and front springs, manual hubs.
The engine and transmission is in, I had a custom power steering hose made, replaced the EGR with a homemade IAT bushing in the intake. Peeled the crap off the stock engine harness and re-taped it with the adjusted connector positions. Amazingly enough, the OHV harness fits nearly perfect on the SOHC engine, just minor adustments in positions were needed.
Anyway, Ill get some pictures up very soon, but here is a couple of teasers.
