- Aug 30, 2007
- Age
- 39
- Cass Co, Missouri
Nice work.Could you possibly get me a pic of how your ran your front brake line? Im in the parts gathering proccess on my truck and i cant seem to figure out how to run the brake line. Thanks.
I'm not finished but, I rerouted my front brakeline down the driverside frame rail to where my fuel filter is, turned it 180*, then used a rear brake hose from a 95 Caravan to put it down to my drivers side radius arm, then ran it to a tee block, then I used 78-79 bronco front lines/hoses by cutting 6" out of the right side.
I'm still working on the mounts for all the lines though.
Once it's done, I believe it'll be better than two super long, expensive braided lines that would just seem to get caught up in the springs and tires.
I think I have about $25 in the front lines. The Caravan hoses are known to go bad, so finding new ones in the j-yard is easy, and the FS Bronco lines were cheap at AutoZone.
I'll also be using another Caravan hose to extend my rear hose.
could you post pics of the under side of your hood
Of my engine compartment or the hood it's self?
If this is about having a hole cut in the bottom of my hood it's not there yet.
Too busy with the suspension and drivetrain.
