2.3L ('83-'97) OBD code KC20
Featured Build Threads
moretsky99
Forum Member
Pensacola area of Florida
FL - USA
Vehicle
Drive
2.3L
14"
I'm pulling a KC20 code from a rather cheap Cen-tech OBD2 reader. Vehicle is a 96 Ranger, 5 speed manual.
I'm getting idiot lights for "check engine" and another one for "ABS". Not worried about the ABS, I'll take care of that eventually.
Recent work:
I recently fixed another code generated message having to do with the O2 Sensor. All I did was clean the sensor and re-install which took care of that; I just put a new O2 sensor in just in case.
I recently replaced a loose shifter with a manual shift rebuild kit.
I'm not finding anything on the KC20 code.
Any ideas?
Allen
"KC" is used in service data pinpoint tests. KC1 through whatever. I'm still looking although I'm not entirely sure why a code reader would give you that.
  • OBD code KC20
Thanks for checking. Appreciate your time.
Just wanted to follow up in case someone uses this to diagnose his/her issues.
After replacing the O2 Sensor on the lower exhaust, I drove the car a couple of times. Eventually the code cleared. So seems that KC20 code was coming from the O2 sensor.
Featured Ranger Based Vehicle
