- Aug 11, 2007
- Age
- 69
- Ontario, Canada
- My credo
- Love Thy Neighbor
I took off my EGR valve and it was totally gunked up to the point the valve wouldn't move. I was able to clean it out w/ carb cleaner and wd40 and get it moving again, reinstalled it, but didn't fix the problem.
I've physically held the butterfly valve open, but didn't disconnect it, no help.
Mine was like that too...full of gunk...I actually removed the carb and cleaned out the passages to the PCV valve and the inside of the carb...if the EGR was plugged up there is a good chance that those parts are too...you will see it when you pull the carb...
OK...so the choke did not help...and cleaning the EGR did not help...have you recently moved the distributor...as in turned it either clockwise or counterclockwise?
I used to adjust my Idle partially by doing that...and it is really simple to do...just loosen the bolt at the base of the dizzy...and, since you have low idle, try moving the dizzy counter-clockwise as this tends to advance the idle...
