If you have ignition spark and you have fuel all I can say is maybe your timing is off.
Could you tell me how I can check for spark? I initially thought spark also since I was putting fuel into the carb manually and it still would not fire. I changed the spark plugs yesterday, along with the wires, so I know it isn't a plug issue. What causes the spark plugs to "spark?"
Can screwing up the order on my distributor cap to the spark plugs cause the engine not to fire? I'll try and find a diagram for this.
Thank you for your help.
