jasongind
So I have an '88 with the 2.9L. I bought it and it had a cracked head. So I replaced the heads and everything associated with them (gaskets etc). Well a few months down the line I was driving to work and it died on me. I poped the hood and I had coolant flowing out of the upper intake. Get it home pull the heads and the right one was apparently never rebulit, all the guid seals were loose and it was warrped. So i bought some aftermarket heads, thicker walls and all that, replace everythng once again...
No problems for the last 7 months and sat I was driving on the Interstate, noticed a rattling sound coming from the right side of the motor. Like the valves were chattering real bad under acceloration above 55mph, it started to get hot. I got to where i was going popped the hood once it was cool, check the coolant and i was really low, looked under the oil filler cap and it looks like a milkshake under the cap.
Is there anything else that it could be besides the heads or gasket that could be allowing the coolent to mix with the oil. I'm about to just get rid of the truck and get somethign different after all of this...
