2001 3.0 need help with coolant in the oil
krucksly
Socal
So I've been having a problem with coolant dumping into the oil pan after I put new heads on this 3.0(due to the valve issue) Used Mahle set of gaskets when reassembling, has a manual with me so everything was torqued properly. On first start it was running super rough with lots of coolant quickly filling the oil pan. Did some reading and suspected the lower air intake gaskets (I did not rtv these the first time) so I did a compression test on all the cylinders and the glove test on the rad, both came out good. So I installed some new lower intake gaskets (felpro) and ran a small amount of rtv around all the ports. Started up perfect and runs great, idles smooth but I'm still getting coolant dumping into the oil, not as much but still a lot. It seems like it will drain the rad to about the half way point, so I'm thinking maybe timing cover gasket? But why would it go bad while I was changing the head gaskets if it didn't get touched? I'm at somewhat of a loss, any help would be appreciated
