1994 Ford Explorer Clutch - Help Needed
Featured Build Threads
TrapperMan2024
Forum Member
Minnesota
Hey All-
I swapped in a 1994 4.0 in my 1986 Ranger, along with the manual tranny and t-case...
I installed a new slave cylinder and master cylinder. I have bench bled (ford specific) and used the mity vac bleeder to remove all the air and play in the clutch master cylinder. And when I hooked it up and bled the remaining slave cylinder, I still cant get the tranny into gear when I push the clutch in. What am I missing?
I've ran quarts, yes, quarts of fluid through the system witch no change. There is a viewing window on the drivers side of the tranny and when I my son pushes on the clutch, it appears to move the clutch about an 1/8" of an inch. How much is it supposed to move? What am I doing wrong?
new install that has never ran?
with the engine off & foot off the clutch can you go thru the gears? that checks the tranny.
You should get 5/8” to 3/4” of travel. Can you bench bleed the clutch master cylinder? There are good utube videos.
I had that problem recently. The firewall had a tear and the master cylinder was pushing out when I pushed the pedal. At least something you can look for...
I've had that happen to me too. And another is the master bolt flange was broke on another truck causing the same problem.
Event Coverage
Featured Ranger Based Vehicle
