Project Boring - 1987 XLT
Featured Build Threads
pax
Saint Charles
MO - USA
Vehicle
Drive
2.9L
Picked up an 87 Ranger XLT 2WD with a manual trans last night for $500. It cranks, but doesn't start. The truck as a whole is in pretty good shape.
Bought the truck with the idea to be a decent pal around daily that I can learn to weld on, since some rust needs to be repaired.
My current daily is a 99 K2500 with a 454, so gas is not it's friend. I also have a 68 Cougar XR7 that I am working on restoring as well.
Going to spend some time this weekend diagnosing the no start condition. I think it's fuel pump related, so we shall see.
Hice find. Would love to see the 68 Cougar XR7.
I haven't spent a lot of time working on it lately
Next summer we're tearing it down to chassis to start body repair and rust repair
302ci, manual car, 4 wheel disc brakes, AC car, sunroof car
Thinking we're gonna pull the 302 and put a Barra and a 6466 on it with a TKX mated to it.
  • Project Boring - 1987 XLT
If you find its fuel pump related...
These have a dual pump system with a low pressure pump in the tank and a high pressure pump on the frame rail basically under your left foot. Those high pressure pumps have a habit of the spade terminals getting loose. Sometimes tapping on the pump will bring it to working temporarily. Fix is new spade terminals. They are hidden under rubber wire covers.
Today here is the plan (assuming the rain stops)
- Check Inertia Switch
- Check the EEC Computer Relay
- Jump the fuel pump via diagnostic test port
- Try and start on starting fluid
- Replace Relay
- Check Terminals on Fuel Pump
It cranks nicely and sounds healthy.
Event Coverage
Featured Ranger Based Vehicle
