Is it possible to flush out oil deposits from rocker arm cavities? Pics inside.
Featured Build Threads
RobWigglezz
Forum Member
Park
MI - USA
Vehicle
Drive
Question everything
Here's the passenger side rockers of my 00' 3.0L with 150K miles. Runs perfect, just wanted to see if there was any obvious excessive wear.
It seems the heavier oil deposits like to collect in the pocket of the rockers. I did clean this side up, but haven't touched the driver's side.
Is there any miracle goo that can collect and suspend these deposits long enough to make it to the oil filter.?
I just cut open my oil filter and it is doing it's job collecting these deposits. They aren't gritty and just smear into sludge. Is there anywhere else that likes to collect this stuff like the rockers do?
  • Is it possible to flush out oil deposits from rocker arm cavities? Pics inside.
I cleaned mine, years ago. It was so bad, the oil wouldn't drain right at extreme up-angles. I just cleaned everything under the valve covers real.good by scraping, brushing, spraying with brake cleaner, wiping with rags and blowing it out with air. Then I did an oil change and added a little bit of Marvel Mystery oil. Then, after driving a few hundred miles, I changed the oil again.
More frequent oil changes and maybe substitute 1/2 quart of oil with ATF.
@PetroleumJunkie412
Did you do before and after with the valveoline restore and protect?
I thought I remembered you posting pictures of the inside of the head on your sohc.
I got it with 137k and I go 3k between oil changes.
Event Coverage
Featured Ranger Based Vehicle
