4.0L OHV Soul crushed and seeking advice on starting problems
Featured Build Threads
There should be plenty of used transmissions around if you just want to drop it and replace it yourself.
Honestly, I don't really want to. It's a mix of us hitting the winter season, not having a garage, and that I already did replace the flywheel last year.
I think I want a shop so I end up with a warranty and if something goes kaput it's not my problem.
If it has a ball joint or tie rod end problem, I would get that fixed right away. There is the possibility of a loose ball joint or tie rod end separating, and that is the sort of thing that can kill people.
So I did the smart thing and I called up les schwab and just explained the sitch.. they'll work on it and said if it won't start on the lift they'll push it off.
Tires I had picked out for myself last year were on sale and the ball joint prices came down a little bit...
Scheduled for tomorrow for tires and front end work :)
So 2 ball joints became 4 ball joints...
That + the ATs ended up being $1700 so other than maybe buying a fuel pressure tester I don't plan on buying anything truck related for a while lol.
But! I am quite happy to have new tires and the front end feels solid on the truck now and finally it's no longer pulling to the right.
Also my self assessment of the bumpy, not right feeling ride seemed to have been fairly accurate.. I was told the passenger ball joints were very loose
These trucks generally take to being fixed up rather well. I’ve come to terms with the fact that they will cost more to fix up and maintain than they are valued at years ago. Still beats a modern vehicle.
My F-150 I did a bit of an overhaul at one point. Think I dropped like $3,100 in three months on it. Then I drove it changing mostly just oil, tires and brakes for 10 years. None of that cost was labor, I supplied all of the labor in the driveway. That was well worth 10+ years to me. My F-150 is basically a bigger Ranger, TTB front and all.
When you take cost for upkeep and repairs into account, don't forget to know replacement cost. 40,000 or more for a new truck will do an awful lot of maintenance and repair!
And you're not giving the government tax money twice. Once in income and another on purchase.
I accepted long ago that I will be exceeding the value of the truck in repairs and I am okay with that. I like this truck, it's mine and it's the first manual I've driven more than a couple hundred feet. It's just a lot of money and I need to pay that off before I make any more big expenses towards it.
I'm happy to have it aligned with new tires though and they reported the rest of the suspension is tight, though I guess I should consider doing the front brakes at some point moderately soon. (are springs at all worth considering if they aren't broken?)
I hope that once I finally get the money and get the transmissions, fly, ect sorted out this truck will be reliable for a good long while :)
Would also love to spend money on improving cleaning up the body and interior as well as generally improving the truck instead of just repairing lol
Oh not only that, but I currently have no desire to have an auto loan that I need to pay off, I've only heard bad things about the reliability of modern vehicles, and honestly modern pickups don't interest me that much. I like my compact truck a lot
The biggest point, that a lot of people just don't get, is that these types of vehicles are simply not made anymore. Can't get a brand new one, like these, not for love nor money.
Soooo . . . we're all left with having to dip into a shrinking pool, of survivor 30+ year old trucks, if this is what we want.
Yes, parts availability is becoming an issue, but that's life.
In my (admittedly biased) opinion, the '89 through '94 models hit a real sweet spot, with still having old-school simplicity, yet with just the right amount of electronic tech for decent engine management. They're relatively easy to work on, cost effective in use (i.e.- transportation and reliability) and they're honestly fun to drive.
For a person with the right priorities, and skills, these trucks are good investments.
And learning to do your own maintenance and repair, is one of the best investments that you can make, in yourself.
You're doing good with that old truck; pat yourself on the back.
Most likely no need to replace springs, but it would be good to look at the bushings in the ends of the leaf springs to make sure they are not all shot. You can get all kinds of funny ride, handling and steering issues if those are bad.
Yeah a simple, compact truck isn't really a thing these days. Even just a simple truck is a fairly lost concept...
I'm pretty fond for how bricknose fords look too, though from a technology perspective I do wish my truck had OBD2 (for the live data). I have been tempted at the idea of a standalone ECU regardless of how unnecessarily it may be. Supposedly based on a rebuild I saw on YT it also can yield a much smoother idle. Would be a pretty cool learning experience, too.
I appreciate the kind words, thank you :)
Thanks I'll have to add those to my list of things to check. I was doing some googling the other day and was informed that those rear measurements for my truck might indicate some potential axle damage or at least something funky in the rear. Oh well, it'll get there eventually
...I do wish my truck had OBD2 (for the live data)...
I thought the same thing for awhile myself. But my 91 harness and 92 PCM can do live data. I'd bet a 91 can too. I doubt Ford would include the wires if the PCM wasn't ready yet.
Just need a kinda hard to come by scanner. Mine is a Actron CP9190. There are other models though. Lots of research into figuring out what would work and I could find for sale.
Yes I have gone down this rabbit hole a couple of times. As far as I can tell my truck does support it, I'm just yet to find a scanner that I can confirm has support for it while not breaking the bank.
I may be able to DIY a solution and have had this saved for some time, just not super motivated to dive into it.
Event Coverage
Featured Ranger Based Vehicle
