- Jun 11, 2025
- Brunswick, Maine
Hello, I have a 2011 XL 2WD with the 2.3L. Truck is in great shape. No rust. 111k miles. Runs great. When I bought the truck about a year and a half ago it had a traction control light on. Very shortly after the ABS light came on as well. I have made multiple attempts to fix this including putting a salvage module and pump in it twice, sending the original module to be "fixed," pairing the original module with a different pump..... Best I was able to get was having all the codes except a VIN mismatch code to clear, so I'm pretty sure it's not a wheel sensor or brake light switch. I have had a local dealer try to reprogram the module. They were unable. I had another company that supposedly specializes in auto pcm and module repair/programing fix it and they were unable. At this point I am considering trying to find a junk Ranger that has no dash lights on, pulling the pcm and the abs module and putting them in my truck. Is this a viable option or would I run into issues with other modules in the truck that would not match up with the salvage pcm? I've been trying to fix this for over a year and am getting pretty fed up. I talked to a different Ford dealer today and they said a new abs module, diagnostics and such would probably have me in the $3000-$5000 range to repair. I'd appreciate any help. Thank you all.
