Gaging interest in resurrecting the Shiftster
Featured Build Threads
^This. It's to the point that you need rotational force, then you have the problem of locating your stops. Before you know it, you've made the shift motor again...
I can't say I'm interested in owning this since my transfer case is manual shift.
I bet there would be interest in a remote shiftster option! Instead of attaching a round knob to the place formerly occupied by the electric motor, add a lever. With this I bet you could adapt a short automatic transmission push-pull cable and a hurst-like ratchet shifter to make the transfer case shiftable without laying in the mud.
I think the problem with a cable actuated from the side is the shifter needs to turn approximately 270°. And I'm not sure if a twist type cable can work.
I've posted before about creating a drum (pulley) & cable mechanism to shift these, with a 'wind-back' spring that returns the drum to the 2WD position when cable tension is released (a lever pulls the cable, unwinding it 270° from the drum (shifting it thru 4-HI, N, finally to 4-LO)... Pushing the lever back releases the cable, the return spring then rewinds the cable back onto the drum, returning it to 2WD)... Or maybe a small rack-n-pinion gear with a solid push-pull cable (rack attached to end of cable, pinion mounted on the shifter shaft).
I'd probably have more ambition to design something like this if I had a malfunctioning e-shift case, but mine are all manual. But I still can brainstorm ideas for you guys to use though... :)
I've never seen that post, but good idea.
You're talking about a spiral spring right? Like a giant clock spring, an actual time piece clock spring, not the one behind your steering wheel. Not sure hot much erxtra machinging it would take to fit in a spring that would work for that. Seems like it would have to be pretty large and strong. Also if your cable breaks then the spring automatically runs the selector all the way back in the other direction.
You could do it like a motorcycle twist throttle. Some like my Honda have two cables with a drum like you described on the carburetor, one cable pulling in each direction. On the bike both ends are doing a twisting motion, but a lever with enough throw should do the same thing. Move the lever in one direction and that cable pulls the drum in that direction. Move the lever in the opposite direction and the other cable pulls the drum in the other direction, rewinding the first cable as it goes. Each cable would have to wrap around the drum far enough to get the full range, so there would be overlap at the ends. Add a detent and plate at the lever end for positions. If one or both cables break it's going to stay in last position since there's no spring pressure, you've just got to climb underneath if you need to shift it.
Depending on how they are making these new ones, it could be as simple as developing a lever/cable/drum system that can attach to or in place of the knob. That seems like a whole separate project for someone to figure out after the basic unit gets out there.
Another thought. this would require a hole in the floor above the shiftster and a strap/ bar to stabilize the shaft that goes through the floor. but put a ring gear on the shfster in place of the knob, run a shaft with a worm gear that engages the ring gear up through the floor and then put the knob on the end of that shaft. you would probably want some kind of rubber grommet to keep dust and water out of the cabin. also might have to do quite a bit of cranking on the knob depending on the worm gear/ ring gear ratio. but it would be a simple mechanical device. will need to service that gear with some grease occasionally unless you enclose it which will add more to the cost/ complexity.
AJ
Correct, like a clockspring, or maybe even more like a shorter/smaller version of the spring on a roll-up garage door pulley system (I want to say the throttle return spring on the throttle body is like this too). It would have to be strong enough to overcome the shift detent resistance in the t-case, plus maybe another 50% more just for reliability. The detent resistance isn't very much, a few inch-lbs I recall.
A broken cable would cause it to snap back to 2WD, yes.
AJ
Use a 4:1 gear ratio:
One full turn = 4-HI,
Two full turns = N,
Three full turns = 4-LO.
Three turns back the other way = 2WD.
This one, a user started to do exactly what JoshT explained using two cables (I forgot about this one):
OP ran out of $$$ and never finished it though.
Maybe I'm overthinking it, I tend to do that, but I see this being a very bad thing.
Cable rotates the shaft through this pattern:
2 => 4H => N (unmarked but there) => 4L
If you use a spring an the cable snaps, it rotates the opposite direction until it stops in 2wd.
If you're in 4H when it snaps, it jumps back to 2wd. Mostly an inconcenience. If you happen to be pulling hard in 4H and the front axle suddenly disconnects, it does suddenly drop all that load onto the back axle and driveshaft. The shock load couldn't be good for them.
There's no Neutral position marked on the selector in the cab or on the outside case, but there is one built into the transfer case. Locating it and placing the transfer case in the neutral position has been mentioned as one of the perks of the Shiftster, and there a few reasons to want to use it. One is flat towing, it neutral disengages the disengages the transmission from the driveshafts so it isn't being spun tow. Imagine if you will that the cable pops while you're being pulled along at 35-55 MPH and the transfer case drops back into 4H then 2wd. The pump on the 4/5R transmissions is on the input shaft, if it isn't turning the fluid isn't pumping, so suddenly you're running the transmission dry. Imagine if the transmission were in the park or a gear position (forward or reverse), being towed because it was stuck there, or not thought about because the t-case is in neutral. That shock load definitely wouldn't be good for the system. In park it's probably going to break the parking paw, in gear its going to do a bunch more internal damage.
Finally imagine if you had it down in 4lo on the side of a mountain, pulling hard, trying to climb up and over an obstacle. Cable snaps. Transfer case drops into neutral. It's like breaking a driveshaft, except it's both of them are gone simultaneously and you're free to toll down hill until you get on the brakes to stop. While you're reacting to that the shaft continues on around to dopping into the 4H and you have that shock load again, except it's a lot worse because your engine RPMs shot up from the loss of load and you were freewheeling backwards down the hill/obstacle. Talk about a bad situation. If something wasn't broke before, it probably is now.
I wouldn't place bets on any of these actually happening, but IMO spring loading the shaft creates and/or amplifies the possibility and asking for trouble. There is a reason that the Ford put in controls to prevent the transfer case from shifting in certain conditions. Pure manual operation you atleast have the human controls to mimic that. The spring isn't going to care.
Glad to see I wasn't the only one with the idea, but unfortunate that he abandoned the project. I think he would have been better off to start from scratch, than try to adapt the parts he was using. It wouldn't have been an option then, but with todays 3D printer filaments, you could probably design and print a functional and usable drum to adapt cables to the Shifster. You could probably 3D print the whole conversion kit except for the cables, but I'd rather have a solid material for the lever and mounts.
I see your point...
But at the same time the dual cables are not going to hold it in 4-HI reliably either if one or both cables break, since the case itself has no detent there; it popping into neutral while going up a hill is still possible from 4-HI (additionally, like you said, the spring will eventually take it to 2WD where at least the rear axle is still engaged (preventing a complete freeroll backward down a hill)... If it falls into neutral with the dual cables however, it's going to remain there indefinitely). Two cables also adds a bit more complexity since there are two cables to deal with instead of one.
IMO I think it's six & one-half dozen of the other here... I think that if properly designed with an appropriate-sized cable (or cables) for the job, the setup can be reliable either way.
I feel the convenience of not having to crawl under the truck each time outweighs the risks of a cable breaking.
An argument also can easily be made for simply keeping the factory E-shift setup in place, and having the Shiftster on hand just as a backup for if (when) the e-shift fails (what I'd probably do myself if I had a still-functional e-shift). The lever / cable / drum setup would make more sense for someone whose e-shift has already failed.
As long at you don't have the cables overly tight in the dual cable setup, it shouldn't move if one or even both break.
I've read about enough cases of the shift motor failing and people using a pair of pliers to shift that I'm not concerned about it moving on its own. Shifter was more created as an easy tool locate the positions and turn the shaft. The detents were added, but did not seem to be a real necessity.
I the unlikely event that it gets knocked into neutral, climb under and use the big ole drum to turn it into position kust like you would with the knob.
Backup device is what they were originally created for, and my sole purpose for getting one. I will keep the e-shift motor in place. In event it fails on trail I'll swap in the shifter to control it until I get home, diagnose, and repair. I could just go under there with the pliers and shift it, each time it's needed, but I'd rather swap in the device and just crawl under there to turn it.
Can it work as a permanent conversion for a e-shift case? Yes. Should it? Probably not. If someone wants that, swap in a manual case and shifter asap.
Just my 2 cent in it.
I'm not sure if it's a backup device or a preventive measure. As long as I had a shitster in my center console, I never had trouble with the shift motor.
:agree:
Shiftster is great for like Eric's use, throw it in the glove box just in case.
If you want a manual t-case just find one. A swap will be easier than trying to come up with a cable/chain/gear drive shift mechanism to manually shift a e shift case day to day.
Event Coverage
Featured Ranger Based Vehicle
