2010 Ford ranger, front sway bar end links, which brand???
Featured Build Threads
slater50
Forum Member
San Diego
Ive got over-analysis paralysis on this one...
Kids 2010 ford ranger has the typical worn front sway bar end links,
heard many nightmares that many brands dont last....
My suspension guys I use to work with always say for Motorcraft...
Anyone have some good success with any brands they would recommend?
moog, precision, ksp, Detroit axle, etc...
My heads spinning.
Dont want to do this again in 6 months.
Thanks!!!
Since sway bar links don't affect alignment, I'd go with the second cheapest and hope for the best. I've never actually had a problem with Moog stuff but I think they changed recently to more overseas production.
just reading reviews, seems like majority dont last...
Not sure if its install error....
Sway bar links will wear out faster for people who turn often (think live in a city) or have other parts loose. Also keep in mind most people don't write reviews unless they have a problem.
Best of luck whatever you go with.
I’ve gone to using Duralast (Autozone) since they have a “lifetime” warranty (basically as long as you own the vehicle). The bushings have a habit of dry rotting through in a year or so but there’s a Gold option with urethane bushings that I’m inclined to try the next time around (upgrades you pay the difference if you warranty something). The design of the front sway bar links on the 98-11 trucks, IMHO, is hard on the bushings no matter what brand.
It doesn't matter. There are two types. If you go to Rockauto and look at the Motorcraft links, they have a different bushing from most of the other aftermarket brands. Although, you can buy aftermarket links with the same bushing types. Also check you sway bar bushings. Generally, they last a long time, but squeak with age. The squeaking can be the result of lubricant getting washed out, or it can be caused by not tightening the links adequately.
I got the ksp links in route…
Have some ford caliper slide grease to lube the polyurethane bushings.
I probably do the sway bar bushings but the look fine.
Energy makes some but need to measure the diameter of the bar.
I’ll do that soon…
One thing I've found, why it matters with the suspension on the 2010-2011 Rangers is beyond me, is that the front sway bar end link install success depends on the suspension supporting the vehicle's full weight while installing them, or they won't seat correctly.
As far as brand, get the cheapest one you can with a lifetime warranty. And make sure you give the bolt shank a coating of never seize so that replacement next time is easier. That way, the sleeve won't become rust bonded to the bolt shank and you will have a prayer of being able to unbolt the thing rather than having to cut it out.
I ended up ordering the KSP‘s, $22, polyurethane bushings, they seem stout..
Supposed to be here today.
Yes, I don’t plan on lifting the truck off the ground to install them, should be easy enough…
I also live in San Diego, not dealing with rust & salt..
Bumping an old thread rather than starting a new one...
Does anyone make an extended length front sway bar end link for the 07+ to 11 torsion bar suspension front ends?
Aftermarket keys with a little crank to even things out and I've got gaps between the bushings and the sway bar on the top ends of the links and they are at an unhappy angle.
Longer links would solve the problem.
I know there were a number of companies that made them for the GMT 400/800 torsion bar suspensions and obviously the Jeep coil spring setups ...
Not that I've seen. I have pre-2008 torsion keys in my 2011 and the end links fit fine. If you have old ones, it is possible that the bushings have hardened up and won't conform to the new angle.
One trick I did find is that full weight of the vehicle needs to be on the suspension when installing new ones, or the bushings won't set correctly.
Event Coverage
Featured Ranger Based Vehicle
