advice for finding good fuel injectors for the 87 2.9.
Featured Build Threads
JLArangerdriver
Forum Member
RALEIGH
NC - USA
Vehicle
Drive
2.9L
about 4 inches
na
235/75 R15
I needed new injectors after my fuel tank started rusting out and clogged the old ones. I put in a new tank, cleaned and flushed everything and installed some SKP injectors off rock auto. Now I have rough idle with random misfires on a few cylinders that smooths out at certain RPMs and engine loads. At higher RMP and load, misfires return. It's not backfiring, or shaking severely. I'm pretty sure I got some bad injectors that arn't sending enough fuel to some cylinders. It's also low on power. anyone have recommendations for decent injectors? I don't want to spend more money on bad injectors.
EDIT- I've done compression tests, good compression and everything was pretty even. new plugs and wires were installed with the injectors. new rotor cap and button, very hot spark. I'm pretty sure my issue is with the injectors. I've been driving it like this sparingly.
Any chance your old injectors could be saved?
My injectors were leaking, so I sent them out to get rebuilt.
They still leak, but not nearly as much as before.
I'm now on the hunt for another set (used original), and have them rebuilt as well.
Hoping to get at least 6 good injectors when I'm done.
RockAuto has both new and reman injectors available.
A few things here. First, looking at Rockauto I see SKP, Standard Motor Parts, and remanufactured. Looking at the SKP website, I'm guessing they source parts from manufactures and rebrand them under their SKP name. But, I could be wrong. The point here they may be an importer that doesn't hold manufacturers to any type of specifications.
Second, the listing for Standard Motor Parts shows three part numbers for injectors. Did you install the correct injector?
Third, did you verify fuel pressure?
Also, I know Standard Motor Parts fuel injectors are twice as much, but their parts are reliable, if you stay away from their economy line, which is the same rebranded junk from China every manufacturer carries so they have less expensive option for people who don't mind doing the job twice.
i bought a set of remanned OEMs off ebay for my B2....havent had an issue.
Does anybody know the stock injectors part number? I think they were Bosch. I'm trying to order a re-man set
Email them, they have great customer service
put the amazon injectors in several taurii and an edge and some rbv...and some 150 inline and 302s...
mostly good....
precision for oem stuff has been solid.
I did, but it was a waste of their time. they don't have a way to look up injectors for an engine, but I found they do show the applications the injectors are for on each listing. I selected filter by Ford, started clicking on sets of 6 and before long I found a set listed to fit the 2.9. this was after i had sent the email. The Bosch part number is 0280150710, which is one of the part numbers that came up when I searched online for the OEM part number for 2.9 injectors. I just ordered them.
Upcoming TRS Events
Featured Ranger Based Vehicle
