advice for finding good fuel injectors for the 87 2.9.
Featured Build Threads
JLArangerdriver
Forum Member
RALEIGH
NC - USA
Vehicle
Drive
2.9L
about 4 inches
Total Drop
na
235/75 R15
I needed new injectors after my fuel tank started rusting out and clogged the old ones. I put in a new tank, cleaned and flushed everything and installed some SKP injectors off rock auto. Now I have rough idle with random misfires on a few cylinders that smooths out at certain RPMs and engine loads. At higher RMP and load, misfires return. It's not backfiring, or shaking severely. I'm pretty sure I got some bad injectors that arn't sending enough fuel to some cylinders. It's also low on power. anyone have recommendations for decent injectors? I don't want to spend more money on bad injectors.
EDIT- I've done compression tests, good compression and everything was pretty even. new plugs and wires were installed with the injectors. new rotor cap and button, very hot spark. I'm pretty sure my issue is with the injectors. I've been driving it like this sparingly.
Upcoming TRS Events
Featured Ranger Based Vehicle
