2011 Ranger XLT 4X4 - "Business Casual"
Featured Build Threads
Where do you get your carbon? Welding rods? Take apart pencils?
I used to have a bunch of carbon rods in a pile of welding rod. Not sure if I still have those squirreled away.
Ebay. Half inch thick carbon plates are apparently common in glass and solar panel manufacturing. Get them as thick as you possibly can, 1 in is not unreasonable. Also get the biggest plate that you can. Mine has six bolted the whole way around the barrel. Electrolysis works by line of sight, and the plates do degrade over time, so you want as much starter material as you can possibly get in there to avoid having to change plates too often.
Does the water turn to sludge?
Like make the new guy clean out the tank when he does something stupid type deal?
You get some sludge that settles out on the bottom, but the water just stays murky black. I have a bung (lol) on it that let's me hook up a garden hose and drain it. Tbh I never change the water unless I have to work on a plate, then I just drain, scoop gunk, refill, and add sodium carbonate. You can get sodium carbonate in bulk from ebay/Amazon. I bought a 5 gallon bucket a while ago. Still have a lot of it.
For the most part, paint and scale stays on the part like a loose plastic bag. I just pressure wash it and go to town with media blasting when it dries. Nice part about using sodium carbonate and super high amperage is it typically dissolves light oils and some grease while in the bath. Annihilates anti seize as well.
I meant to ask in my previous post, what brand/model is your powder coating setup?
Eastwood dual voltage gun. Its ok. Good for the money. I used to have the super old school craftsman gun and loved it.
The eastwood gun is ok. There's times I prefer the craftsman bombshell.
Eastwood gun is great if your part is hanging vertically. It's a cone diffusion, but is super sensitive to air pressure spikes when my compressor kicks on. It sucks when your part is hanging flat. Usually pre heating your parts mitigates this tho.
The craftsman gun is a stones throw away from greatness. Jet diffusion, and self contained, no compressor needed. Only drawback of it is not enough amps of power to get the powder to stick to the part. Pre heating completely mitigates all drawbacks tho. It does suck for horizontal surfaces and leads to clumping. Also total ass for metallic flake powders. The low amps leads to glitter clumps in the part.
No matter what you do, go hammer a grounding rod in outside and run your part grounding to it along with the gun ground. The extra grounding for the part being coated is critical.
Looks like a good source. Half inch panels for a reasonable price.
Well. Got up and running with the 340lph fuel pump, and....
Great...
Late to the game here but I would check your fuel pressure, only reason I can think that your fuel trims would be out of wack like that is if the pump is flowing more fuel than the regulator can return. I don't know how the regulator system works on the returnless system but you might need to upsize to something that can maintain the pressure and return more fuel when there's less demand.
Next step for sure. I really hope the in tank regulator is intact...
Just photos of progress today.
@Jim Oaks I am requesting a "coilover conversion" profile badge when I get this thing done 🙂
if you ever get around to installing that blower you keep talking about…….
At this point not even sure if it’s real.
My forced induction banner is now missing so I look like an idiot.
Charles still has it 🙄
Like bruh I sent that shi in JUNE
Upcoming TRS Events
Featured Ranger Based Vehicle
