2011 Ranger XLT 4X4 - "Business Casual"
Featured Build Threads
Where do you get your carbon? Welding rods? Take apart pencils?
I used to have a bunch of carbon rods in a pile of welding rod. Not sure if I still have those squirreled away.
Ebay. Half inch thick carbon plates are apparently common in glass and solar panel manufacturing. Get them as thick as you possibly can, 1 in is not unreasonable. Also get the biggest plate that you can. Mine has six bolted the whole way around the barrel. Electrolysis works by line of sight, and the plates do degrade over time, so you want as much starter material as you can possibly get in there to avoid having to change plates too often.
Does the water turn to sludge?
Like make the new guy clean out the tank when he does something stupid type deal?
You get some sludge that settles out on the bottom, but the water just stays murky black. I have a bung (lol) on it that let's me hook up a garden hose and drain it. Tbh I never change the water unless I have to work on a plate, then I just drain, scoop gunk, refill, and add sodium carbonate. You can get sodium carbonate in bulk from ebay/Amazon. I bought a 5 gallon bucket a while ago. Still have a lot of it.
For the most part, paint and scale stays on the part like a loose plastic bag. I just pressure wash it and go to town with media blasting when it dries. Nice part about using sodium carbonate and super high amperage is it typically dissolves light oils and some grease while in the bath. Annihilates anti seize as well.
Upcoming TRS Events
Featured Ranger Based Vehicle
