Cursed? 2nd failure on way home two weeks in a row (tail gate handle broke)
Jeff_Birt
10+ Year Member
Monday last week on my way home the HVAC in my 2011 Ranger went 'defrost only' mode; got it fixed Sunday. Today (Tuesday) my tailgate handle broken when I tried to open it after work. Plastic arm on left side broke. Ford is proud of them wanting $154 for a plastic handle!
I loath Dorman but it seems that have a metal handle for $27 on Rock Auto, $32 from AutoZone and O'Reallys wants $54, Napa wants $60? Found other options for a metal handle a bit cheaper but reviews say they work but are noticeably smaller. Reviews on Dorman part all seem to say it fits fine. Perhaps I'll try my luck with the $32 DOrman part from AZ?
I would, they're really easy to change so a low risk part. Mine was bent on my '97, it was metal and was able to bend it back. Was able to do the same thing on my '90...
Picked up the Dorman 90625 from AutoZone, about $34 with tax. Fit perfect, works perfect. Is solid metal so 'should' not break like the OEM plastic handle.
The handle might have broken because the tailgate latch mechanism was binding, so this might happen again. Had binding on a 1990 Ranger I briefly owned years ago. Some spray lubricant in the mechanism pivots around the handle freed everything.
There was no binding in this case. After removing the access panel I was able to release the tailgate by squeezing the pivot mech with my fingers. I did lube everything for good measure since it was apart though.
Upcoming TRS Events
