LS swap! finally
running better with fresh gas?
Much better. Took it around the block but it has a P2534 Ignition Switch Run/Start Position Circuit code. I cannot seem to clear it or figure out whats causing it for me. Truck is stuck in limp mode right now because of it.
Found a dana 50 ttb and 10.25 for cheap....
LS swap! finally
You planning on making a Jana 54? It'd be the only way to outdo your D35 for travel, it's kinda crazy how cheap you can pick up D50 TTB's and 10.25's up for though... for $500 I have 3 10.25's, two D50's and a TTB D44 just waiting on me to get time to make a Jana 54 and swap that mess into the '00 Explorer...
Well. Here it is.
LS swap! finally
My P2534 code was because my ECU AND TCM weren't turning on/off at the exact same time. I grounded a relay to the ECU on pin 59 black connector. Then used that to control TCM power.
damn....that must have pissed ya off good and proper.....
she is awn now though....
Sounds very rowdy, makes me want to get mine done
Well. Here it is.
what cam?
IIRC BTR truck norris.
