LS swap! finally
running better with fresh gas?
Much better. Took it around the block but it has a P2534 Ignition Switch Run/Start Position Circuit code. I cannot seem to clear it or figure out whats causing it for me. Truck is stuck in limp mode right now because of it.
Found a dana 50 ttb and 10.25 for cheap....
LS swap! finally
You planning on making a Jana 54? It'd be the only way to outdo your D35 for travel, it's kinda crazy how cheap you can pick up D50 TTB's and 10.25's up for though... for $500 I have 3 10.25's, two D50's and a TTB D44 just waiting on me to get time to make a Jana 54 and swap that mess into the '00 Explorer...
Well. Here it is.
LS swap! finally
My P2534 code was because my ECU AND TCM weren't turning on/off at the exact same time. I grounded a relay to the ECU on pin 59 black connector. Then used that to control TCM power.
damn....that must have pissed ya off good and proper.....
she is awn now though....
