172 isn't bad sensor it is lean bank, and "lean bank" (suspect) combined with bucking and idle issues tends to tell us the lean bank is real not false.
Just for giggles I took the same ChatGPT session I built with a lot of commands to tell it not to fabricate, to research, to show sources and prove what it is saying and here is what the mystical AI had to say:
A Code 172 on a 1992 EEC-IV Ford is:
By itself, 172 does not mean the O₂ sensor is bad. It means the ECU has driven fuel trim rich and the oxygen sensor is still reporting lean.
Now combine that with:
- Loping idle
- Bucking at WOT
- Only Code 172
That points much more strongly toward an actual lean condition than an ignition problem.
My probability ranking
1. Fuel pressure / weak fuel pump ★★★★★
This is my #1 suspect.
Reason:
- At idle, a weak pump can almost keep up, causing a lean, unstable idle.
- At WOT, fuel demand skyrockets.
- Pressure drops.
- Engine bucks and surges.
This is almost textbook.
The 4.0 OHV wants roughly 35–40 psi (vacuum connected) and around 40 psi with the regulator vacuum removed, depending on the exact calibration. More importantly, it needs to hold that pressure under load. A gauge taped to the windshield for a road test was a common diagnostic trick back when these trucks were new.
2. Vacuum leak ★★★★★
A significant vacuum leak can absolutely produce:
- loping idle
- lean code
- hesitation
However...
Vacuum leaks usually become less important at WOT because manifold vacuum is very low.
So they explain the idle better than the WOT bucking.
I'd still smoke-test the intake.
3. Dirty or leaking MAF ★★★★☆
1992 was one of the first Ranger years with the MAF-equipped 4.0.
If the MAF underreports airflow:
ECU thinks:
Reality:
Result:
- lean mixture
- Code 172
- especially bad under heavy load
Very common on early Ford MAF vehicles.
4. Fuel filter ★★★★
If it hasn't been changed in years:
- idle mostly OK
- WOT starves
- bucking
Classic symptom.
5. Fuel Pressure Regulator ★★★☆
If the diaphragm leaks or regulation is incorrect:
- low pressure
- lean
- rough idle
Also pull the vacuum hose.
If there's any gasoline in the vacuum hose, the regulator is bad.
6. Intake manifold gasket ★★★☆
The early OHV engines are old enough now that hardened intake gaskets are common.
Produces:
Less likely to explain severe WOT bucking.
7. Injector problem ★★☆☆☆
One or more partially clogged injectors.
Possible.
Not my first guess.
8. O₂ sensor ★☆☆☆☆
Ironically...
This is actually pretty low on my list.
A lazy O₂ sensor doesn't usually produce:
Also...
At WOT the ECU generally ignores the O₂ sensor and goes open-loop.
That's a really important clue.
If the truck bucks at WOT...
...the oxygen sensor isn't controlling fueling anymore.
That pushes me toward fuel delivery instead.
One thing I really like about your symptom combination
The idle and WOT failure have the same direction.
Idle:
WOT:
That usually means one root cause.
Things I'd check in order
1. Fuel pressure gauge
Highest value test by far.
Observe:
- KOEO prime
- idle
- snap throttle
- driving uphill
- WOT
Pressure should remain stable. If it falls during the bucking event, you've likely found the culprit.
2. Smoke test
Especially around:
- upper intake
- lower intake
- PCV elbows (a notorious Ford failure point)
- brake booster hose
- vacuum tree
- EVAP hoses
3. Clean the MAF
Only use proper MAF cleaner.
Don't touch the sensing wires.
4. Fuel filter
If its age is unknown, replace it.
It's inexpensive and can masquerade as more complex issues.
5. Check regulator vacuum hose
Any fuel present:
Replace regulator.
One thing that would change my ranking
I'd want to know:
Does the truck pull cleanly to about 2500–3000 RPM and then start bucking, or does it begin bucking almost immediately when you floor it?
If it waits until airflow and fuel demand are high, my confidence in a fuel delivery problem (pump, filter, pressure regulator) goes up even further.
Current probability estimate
| Cause | Probability |
| Weak fuel pump / low pressure | 40% |
| Restricted fuel filter | 20% |
| MAF contamination/failure | 15% |
| Vacuum leak / intake leak | 15% |
| Fuel pressure regulator | 5% |
| Injector issue | 3% |
| O₂ sensor itself | 2% |
Given only the symptoms and Code 172, I'd reach for a fuel pressure gauge before replacing any parts. A five-minute pressure test can quickly distinguish between fuel delivery and many other possibilities.
I agree with the order of steps just not the percentages. I think bucking at WOT is going to be closer to 90% fuel, so I'd go over the fuel system 3x before moving on to other systems. The other 10% in my mind is user error in the gasket install - extra air getting in causing it to go lean, so would go over the gasket again to make sure no booboo's
