Putting AC in Non-AC Ranger Switch Question
Marietta
GA - USA
Other
1993 Mazda Miata
Vehicle
Drive
235/75R15
I have a 1993 Ranger XL with the 4.0. My truck is a factory non-ac truck and so far I've gotten or ordered everything I need to do the conversion to AC. I've got the box, compressor, lines, condenser, evap core, factory ac control panel, all of it. My truck does have the mounting point for the compressor, the bracket is there complete with bolt holes, my fuse box in the engine bay has pins for the WOT relay, and my truck had all of the fog light wiring already there too, so I'm assuming it already has all of the ac wiring. However, I had a look in the engine bay looking for the 3 plugs for the switches and compressor and I couldn't find them. I found one blanked off plug maybe near the fusebox on the driver side but it isn't nearly long enough to reach the AC stuff. Could the rectangular plugs for the compressor and switches be hiding in the looms somewhere or does my truck just not have them?
@RobbieD I know you use to do some add on A/C back in the day... any help you can offer?
@Curious Hound
I think you at some point installed and then removed the AC from your 3.0 truck?
My truck originally had AC and I removed it. If your truck was originally built withput AC, it likely jas some of the wiring. But may not have everything. I may be able to get pictures of the connectors for you, if that would help. But, if you don't have parts of the harness, you will need to get it from a junk yard or spurce the connectors online and build the harness. I can post photos from the wiring diagrams if you need that.
I can't say for certain. I have a '94, but it's factory AC. I did do a lot of aftermarket, and a fair amount of OEM AC, but that was late '70s through the 80s. Early imports were generally prewired, and easy to add AC, but domestics sucked doing OEM kits, because of how much stuff that had to changed out, on top of the AC components to be installed.
I think that by the mid-90s, Detroit had finally gotten the memo, and started making things somewhat easier. The "fair amount of OEM" installs that I got to do, were from car dealerships paying my aftermarket shop to put their OEM AC kits in their vehicles; their mechanics hated doing them, it was such a pain in the ass.
That's a very good sign, especially if the socket is populated with terminals. The compressor mount being there is also very good.
My "best guess" is your truck may be partially wired.
Hopefully, the one plug that you have found is C113 (see the 1993 diagrams that I include below), which will need an extension harness to go to the compressor, that will also include the AC diode. If this is the case, I'd get the short harness from a junkyard donor.
The other connector that I hope is in the truck already, is C167, for the pressure switch. Look around the passenger rear corner, for an unused loose connector, or an unused one that's taped off to a harness.
I suspect that you're OK on the inside switch wiring, and I suspect that the existing PCM is already wired and will work like it's supposed to.
Use wire colors on these diagrams, and the locator view, to help you in trying find those two engine bay connectors.
Good luck!
