Aces Killshot Fusion EFI Swap
I was playing with the fuel table and shut the truck off for a bit. Went to restart and it started and died right away... and I lost everything. Like everything down to the dome light. All my added on stuff runs off a relay ran by the key power that originally went to the factory coil so without the original truck harness functioning I have absolutely nothing.
So I close out the aces program and pull up my scanned EVTM, eventually come across this:
I cut it out and jumped it and I got lights back.
I just deleted the connector to get the thing back inside before the rain got worse.
So yeah, most of the night was spent on a wire chase.
Did tha melt? Or did it just get accidentally crushed at some point?
Its been hot at some point. It was cool by the time I found it but it took me awhile to get there. It lives behind the cruise servo so I don't really see it often either.
It doesn't instill a lot of confidence in the fuseable link however...
It depends on the size of the fusible link. This connector may have had a loose connection and just barely heating up slowly - more current than ir could handle in that state, but less than the fusible link. I would check to see if there is a fuse for this circuit. Also re-examine what's on this circuit. Make sure you haven't added load beyond what it was designed for.
No fuse, it never has. Straight to the starter relay with a fuseable link right there.
I decided last night it needs a fuse lol
I just spliced it, ran into the garage as it was trying to rain and unhooked the battery for the night.
Just tied up a bunch of loose ends last night. Fixed the backlight for my temp gauge, when whatever happened the other night happened my tach jumped so I pulled the dash/cluster apart and fixed that. Also got power to the tach module again (it was tied in with the fuel pump previously) so it works and also remembered to hook up the speedometer again while I was down there.
The running issue where it falls on its face and starts backfiring at around 2k rpm. I was playing with it on my laptop, the timing quits advancing at around 22*btdc right there and then it turns red as everything falls apart. Not sure what to do about it, I am going to put a timing light on it tonight and make sure I have the dizzy timed right.
It starts and idles great though so I don't know. If it wasn't for the 2k rpm thing I could drive it IMO.
Assuming your using timing tables, you locked out the distributor right?
Asked around on the aces forums , they would know more about it maybe
I am going to double check base timing first and go from there. :icon_thumby:
It wasn't the base timing unless the dampener has slipped in the last 3 years.
It could be an exhaust leak upstream from the O2 but I show it going rich not lean. By the time I checked timing it was extremely hot down around the header so I wasn't really feeling check on that. I don't hear any leaks though. I am going to try that tonight.
I also need to dig into figuring out how to adjust the advance tables I guess. Given that they are pretty standard I would have thought I wouldn't have to. Standard 302 stuff I should be getting 35ish degrees by 2800rpm. I hit a ceiling of 22* at about 2000rpm.
Luckily there is no literature or real guides out there on how to do this. :yahoo:
Rev limiter set too low?
I have never touched it, that is still set at 6500 as it was out of the box.
I can push the RPM above 2k but it is very unhappy, timing doesn't do any more than it is right there.
Can you run vac advance for time being?
Vacuum can is still there... it didn't sound very simple to keep the computer from fighting with it.
Kinda wishing I would have stuck to the original plan where I get the EFI working with Duraspark and then switch the ignition over.
Patience. You'll figure it out.
