2.3L ('83-'97) 92 Ranger 2.3 (manual) cranks but no start
Precisions
5+ Year Member
California
Hello 👋
Im working on a 92 Ranger 2.3. I had the whole engine out and got everything back together and back in the engine bay this month. Now that everything’s back in Im having some issues getting it started. The engine cranks but doesn’t start. Ive tried the 50/50 test resulting in the engine stumbling and almost starting with some starter fluid but never going all the way. I’ve been spraying some in and then running to key to start myself though.
I had the engine and the harness that connects near the driver side firewall and wheel well going to coils and injectors out. I had made good marks on all the connectors and have double checked them a couple times.
Here’s what I’ve noticed/done:
- I hear the pump priming and can confirm fuel is reaching the fuel rail. Maybe most notibly today I checked fuel pressure at the rail and Im able to reach 40 PSI once primed and during cranking. But once cranking stops or a few seconds after the pump stops priming the pressure rapidly drops, then drops slower around 20 psi, and will eventually hit zero. I didn’t get a chance to continue after I noticed this, but I feel like this would lead to a hard to start condition by itself rather than no start?
-My fuel pressure regulator is somewhat new. Pulling the vacuum line has no liquid gas but smells faintly of fuel.
-No fuel leaks detected anywhere around engine or down the lines to the tank
-Fuel pump is relatively new and replaced the original fuel pump
-I don’t have a noid light but I threw on a 194 bulb to some alligator clips and I seem to get a good pulse to the injectors. However, spark plugs come out completely dry
-I had tested the injectors prior to installing them and they didn’t seem to leak and worked when power was supplied.
-EEC KOEO Quick test comes back 111. All clear.
-the check engine light comes on when key is turned and goes off when key is turned all the way.
-timing marks are lined up. The crank pulley mark is at TC when the camshaft mark meets the diamond.
-compression reads around 180 down all cylinders
-I checked spark on the passenger side and saw power getting to the spark plugs. I checked the drivers side and saw no spark as expected.
Ive got a breakout box and tomorrow I was hoping to start taking some readings but now I’m looking at that fuel pressure decrease. Im figuring next I can check the fuel pressure regulator and possibly determine where the fuel is draining back to the tank to. Ive been away from wrenching for awhile and I’d love some additional support/ideas through getting it running. If it’s possible to summon Mr. RonD I’d be extremely grateful to work through something with you again.
Here’s Little Blu, the ‘92. Thank you!
  • 92 Ranger 2.3 (manual) cranks but no start
That pressure drop seems weird to me, but it should get enough fuel to fire at 20psi. I started my 4.0 3 times with the inertia switch tripped. I just wouldn't run but a second.
Thanks for that! I was pretty sure I’d be able to get it to go especially since pressure holds steady while cranking. Not sure why Im getting a pressure drop but at least that seems to indicate I should be able to get something to happen.
I think I’m taking a break for today but I figured I’d pull the injectors and check them out again. Not sure why Im not seeing fuel on the plugs but seeing pressure at the rail and a pulse at the injectors.
As far as the pressure drop, I’ll be able to check out the pressure regulator pretty easily but I’m having a hard time not blaming something in the fuel pump for not holding pressure
If there's any vacuum while cranking the regulator will drop pressure, not to half though...
If it helps troubleshooting as long as you are in neutral with the key on you can just jump the starter solenoid by the battery, either a wrench across the big terminals or pull off the small push on wire and jump power to that to jump the starter.
Yeah not entirely sure what’s going on there. At some point before everything got taken out I had checked fuel pressure and it was stable at around 40. I think it’s strange that it’ll come right up to pressure but then drop all the way back down after releasing the key.
Thanks for that! Didn’t even think of that. I’ll give that a go next time I try to get it to fire up again.
The only check valve in the fuel system is in the fuel pump and at this age they don't always hold pressure anymore.
You said you checked and all of the injectors released fuel when you jumped power across them? It almost sounds like they aren't opening the poppets in them...
My fuel pump is relatively new. I replaced the original one about 2 years ago or so. Although I was only able to get my hands on an autozone brand one at the time..
I figure the pressure loss can only be so many things: the regulator, a stuck open injector, the pump, or a broken line.
Yes I had tested all the injectors with a 9v battery and some carb cleaner before putting them in. I’ll be able to get down to the fuel rail today and get a better look at what’s going on. Very confused that the injectors seem to be getting fuel (at least during cranking and prime) and a signal but not actually spraying.
I have some spare injectors I can try throwing in today too
Give it a whole bunch of ether and see if it fires. If it's still just sputtering or not running at all at that point, I would suspect a timing issue. Sometimes just a whiff of ether evaporates before it can do anything.
There is one wire on your ECM/OBD test connector that you can ground out and it'll make the fuel pump run all the time. I would do that and see if it'll start and run then. If it does then I would suspect there is an issue in the ignition/fuel pump relay/ECM wiring somewhere.
Great to know! I’ll try that out and report back. Im getting a bit caught up today so I might have to give these all a shot tomorrow.
I was content with the sputtering because I wasn’t getting anything without the shot of starter fluid. I then checked to make sure the timing belt and marks were good before moving on to check more fuel related issues. But the wrench to start solenoid and the continuous fuel pump ground seems like it’d give me a better idea on where everything stands.
I’d assume if I can get it to start with the pump continuously running I’d still have to troubleshoot that pressure drop between the regulator and fuel pump but once I get my hands back in the truck I can give some updates.
Also I do have two different ECMs that I’ve tried swapping between. To my knowledge they are both good. Thankfully the breakout box will make some wire shooting easy and I have plans to follow the engine troubleshooting manual I have with that next chance I get
Could you tell me more about the fuel pump relay? Is that one of the relays sitting upside down beneath the engine bay fuse box?
Yes, it's one of the ones under the power distribution box, I haven't had to mess with that stuff so that's as much as I know...
Been a bit sick so I’m moving slow but I’ve got some updates for those interested. Bit of a write up but I’ve done a few things:
Firstly, I’ve been really interested in my fuel pressure drop and figured there could only be so many things wrong there. I went ahead and removed my fuel rail to test the fuel pressure regulator and injectors (again). Both the regulator and Injectors tested good. Additionally, Using a stethoscope on the injectors I can hear them pulsing.
Next, I had a brand new fuel filter on hand so I tried swapping that out, but since then Ive been unable to get the necessary fuel pressure back to the rail. My gauge just sits at zero. Im pretty sure my pump decided to call it quits. Even with it running continuously via the jump I was unable to generate fuel pressure. The pump is only a few years old but was an autozone brand pump that I wasn’t entirely excited about installing. I got a deal on a Delphi pump through rock auto and it’s on the way.
I double checked the fuel lines down the body and the connections at the fuel rail and fuel filter. All looks good.
Other than that I did some wire shooting to check out signal to pretty much every component with a small plug in the engine bay to the computer. Good signals and values from the MAF, TP sensor, injector connections etc
Lastly I tried starting it up on some starter fluid through the intake and have been able to get the engine to running speed and sounding good for a couple seconds. This seems to me to be the nail in the coffin for a this issue being a lack of fuel.
Anyone know any tricks to lifting the bed solo?
Thanks again for all the ideas everyone. I’ll give an update once I tackle that fuel pump.
Edit: forgot to add that I checked my inertia switch and the button is pressed in. But I also doubt that the inertia switch or my fuel pump relay are the problem since I can hear my pump trying to push pressure when the key is turned and while jumped.
