My 2000 Green Ranger 5.0 lowered AWD
after watching the video a few more times....i would just get a frame.
need some southern iron.
I would have liked to have done that. I have nothing to drive to fetch said southern frame with though and no money to pay someone to haul one in for me.
This šŸ‘†
I almost always a bad idea to patch a frame. If one spot is rusted through, there’s probably another spot that’s in the same shape and you haven’t found it yet.
Yes, but, this frame is mostly plated anyway. Passenger side from the rear lower control arm to the front leaf spring hanger and drivers side currently from the T-bar mount back, minus the section I’ve been working on. Entire rear frame section was replaced a few years back. Might as well just finish the job at this point.
i can bring one back one of these trips
that one under there 450 bux....out in cedar utah
So what you’re saying is that it was junk years ago.
this looks like my kind of replacement junk for my junk to make it less junk looking from 60 feet away....
lil bit of rust o leum.....and some ac.....never had it so good.
Unfortunately, yes. And ever since it’s been a matter of I don’t like doing this but I need it…
I continued getting the motor together in the truck and the front end back on. A new radiator/core support went in since mine was rotted to junk. I chose to bolt the new one in instead of welding and used a pile of 1/4" stainless bolts since that will make any later servicing or replacement of the motor easier. I also chose to replace the factory Ranger battery tray with the plastic Explorer tray, which aside from needing some bolt holes drilled, fit rather nicely. The 65 series battery was a little tight on the ABS module and the one ground bolt on the core support. I bent the ABS module bracket slightly to allow room and at some point here will also change the ground bolt for something more compact since I changed how the ground bolt in dad's one Ranger is and I think it would be a good option for mine.
Also during this whole process I decided to invest in some new stuff. I bought a bunch of -6 AN PTFE braided line and fittings to replace fuel lines and other stuff. I bought some larger AN stuff to rebuild some of the heater lines since the ones with my motor were rather rusty. While I was at it, I also got a lever style brake flaring tool to make new hard lines with Ni-Copper line. The lever style flare tools are far superior to the standard cheap double flare tools. I spent the extra for the 37* AN die set for the tool as well.
@sgtsandman came over to help me get some things handled with the project. I didn't get much in the way of pictures, but he manufactured up some brackets for me for mounting a different transmission cooler. Had to make a few adjustments to things, but I managed to mount a transmission cooler out of a 2007 F-150, which is over twice the size of the stock Ranger cooler. We also got a bunch of other stuff handled.
I also, against my better judgement, jacked up the back of the truck and put that on jackstands as well. There was a lot of work to be done on the rear suspension and changing out the rear axle to the Explorer 8.8" rear.
what braided lines did you use on the trans cooler?
it would also be nice for pictures of the piping to the new trans cooler.
-6AN PTFE stainless braided. I connected to 3/8ā€ aluminum line that I ran for hard line connections. The F-150 cooler that I used happened to have threaded connections and I just had to work out what connector I needed to make it mate. Really like how it worked out.
so, you replaced the stock hard lines with a 3/8" aluminum line? I am just trying to work out every little detail. I'm going to go with a similar sized trans cooler since my local junk yards don't seem to have the year range of f150 or e150 with the larger trans cooler.
I just got two smaller generic coolers on Amazon and ran them in series mounted in front of the radiator, for hose I just used rubber hose and clamps, the cooler is on the return side so not under more than like 10psi, if it has enough pressure to blow off there's a problem... I'm pretty sure I flared the end of the factory tube I cut a little bit just for good measure.
after flaring did you use a an fiting or like a hose clamp?
Yes. So if I remember tomorrow I can try to get some pictures and details and all. Been busy and away from home the past couple days and I walked into a headache when I got home this morning.
There’s different ways to do it for sure, I’ve replaced or repaired trans cooler lines for years, used to do it with steel line and rubber transmission hose. Then I switched to aluminum because rust is a real problem around here and I’ve contemplated using stainless. Aluminum is cheaper and easier to work with though. Plus a lot of AN stuff is aluminum so less worry on dissimilar metals.
Dad’s one Ranger has two stock transmission coolers. I was going to go that route and I had a cooler to use but somehow it got water in it and froze which split it. I was in a junkyard contemplating grabbing one when a thought crossed my mind about a buddy that loved thinking outside the box and I looked at a couple vehicles near the Ranger section. Little bit of back and forth with a tape measure and I was pretty sure I could find a way to make a stock 07 F-150 cooler work. Then a little work and here we are.
Just a bump so hose clamps would work... I'll try to get pics tomorrow of whatever I cobbled together 10 years ago...
Yeah, I’ve used a flaring tool to bulge tubing before for putting rubber line on. I should probably do a video on it all now that I have something resembling a workshop.
Upcoming TRS Events
Featured Ranger Based Vehicle
