1999 Ranger No Crank Electrical Gremlin
SomeBakerGuy
Forest
MS - USA
Vehicle
Drive
2 inch suspension
285/70R17
Hi All,
This might be a long post but I am out of options and really need some help.
Truck:
1999 Ford Ranger XLT 4x4 Automatic w/ PATS
Issue:
For the past several months I have been experiencing an intermittent no crank no start. It has since progressively gotten worse until now where I am dead in the water. Previously turning the key to crank position would result in a audible 'click' and all interior electronics would go dead. Even if the key was removed and reinserted. The only solution was to disconnect the battery and try again. This did not occur every time and would sometimes go weeks without issue. In total this has gone on for the better part of 2 years. Until now.. It got to the point where I was having to disconnect the battery several times to get the truck to turn over without all the electronics going dead. Once the truck was started I had no issues. For context my battery is brand new and the alternator is about 1.5 years old.
My battery cables were looking rough so I pulled the harness two weeks ago and replace the positive cables to the starter and the relay box under the hood as well as the negative cable to the block. Truck turned over and fired on the first try, ran for about 30 seconds and died. Died as if you turned the key off. I will note even before I changed battery cables I was experiencing odd interior electronic issues IE. intermittent dome light, key chime, windows, cluster issues, etc. Since I've replaced the battery cables I no longer have the issue of the interior electronics all going dead but when I turn the key to crank nothing happens. I have gotten the truck to run 3 or 4 times but only for a few seconds before it shuts off. When it does crank it fires right up.
With the key in the on position and pressing the window switch the power window relay under the dash buzzes and the windows do not move. The dome light is intermittent and I'm getting erratic readings on the cluster gauges even with the key off. The key chime works intermittently and I can manipulate it by wiggling the key in the tumbler. It does not chime in the key-on position and I cannot get it to do so. The few times it has cranked it will chime in the on position.
What I have tried:
New/Different Battery
New Battery Cables
Probed fuses and checked/swapped relays.
Checked several grounds
Truck turns over when jumping the starter relay
New GEM module
New Ignition Switch
New Ignition Tumbler
Different Non-PATs key (Chime issue still remains)
Verified column actuator from tumbler to ignition switch is functioning
Tired starting with key in ignition but manually flipped the ignition switch (no change)
I would say I have tried nothing and I am all out of ideas but in this case I am at a loss as to what to try next. I could go on but this pretty much sums it up. It seems to be grounding or shorting issues but I cannot track it down. The few times I have had PATS related issues the "Theft" light would illuminate on the dash but I am not seeing that now. The key chime with the PATS and NON-PATS key is intermittent with the key inserted.
Should I test the PCM next?
Any help is appreciated. Thanks!
Your original issue was loose connections at the battery and or the cables. Like you said you fixed that with the new cables. But putting the new cables on, where you bolted the battery + to the starter solenoid, there should have been some smaller wires with large ring terminals that are with the battery + cable. These are what feed all the electric of the truck except the starter itself. I think you need to take the battery + cable off again, and check the condition of these smaller wires. If the ring connectors look rough, replace them.
What happens a lot also, one of these smaller wires will fall down and get forgotten. Look around and make sure they are all on the terminal and in good condition.
So on the 99 4.0 the starter solenoid is mounted on the starter. There are three wires going to the starter/solenoid: positive from the battery, negative from the battery to starter mounting bolt, and ignition wire to the solenoid. I did take the starter back out and adjusted the smaller ignition wire but no change. I also disconnected the ignition wire all together to see if any of the electrical gremlins changed. They did not.
I disassembled the ignition tumbler and grounded the key chime manually and got the same intermittent chime. I am getting about .9-1.0 volts to this chime switch but I am not sure what it is supposed to be. Where do the interior electronics ground? I have checked the ground behind the driver kick panel. Do other electronics ground through the firewall to block ground strap under the hood?
Ok, sorry I was in thinking in the older truck world. Your newer truck has the "starter relay" in the underhood fuse box.
Checking grounds again this morning I haven't found any of these to be bad. However, I ran a couple feet of wire from the negative post on the battery and touched the other end to various grounds. If I run the ground wire to a random spot on the steering column my issue goes away and the truck starts and runs fine. So there seems to be a ground issue somewhere around the steering column.
That's good troubleshooting. Glad you found it. The outside of the column should simply be bolted to the metal part of the dash. Not sure on your truck, but many Fords have a internal rubbing block to ground the steering shaft itself, since usually the bearing in the top near the steering wheel is mounted in rubber, and then you have the rubber rag joint down near the steering box.
thank you for taking the time to post these awesome diagrams.
Hi All,
Truck:
Issue:
What I have tried:
New Battery Cables
New GEM module
New Ignition Switch
that is a big thing. and this tends to be the ground issue or power issue feeding/commanding via the gem.
this is similar to the fullsize trucks where i have seen water intrusion cook ground or powers and cross communicate ect causing ghost issues....radio and lights and windows doing what they want. often the gem is blamed but it is corrosion in the fuse/relay panel.
might be worth a bit of time to pull the fuse box out of the side panel a bit to look for obvious signs of corrosion or water on the box and maybe some cooked off grounds.
