Oh wise (electrical stuff) ones……
Keeping in mind that I’m a pretty smart engineer and I’ve worked with all this stuff for the better part of 60 years, I have what is probably a dumb question. And yeah, yeah, I know there are no dumb questions - just dumb people.
30amp fuses. I don’t have a picture of the even smaller more modern fuses like this that I believe also come in 30 amp.
If I’m going to run a wire from here to there in the truck to power whatever, are these two fuses interchangeable because they’re both 30 A? Or does the big one somehow carry more whatever? My thinking is a 30 amp is a 30 amp is a 30 amp, independent of the physical size, when working in the same 12 V circuit.
I’m looking for the correct overall answer. Specifically, at the moment, I’m wiring in some electrical horns and also the little compressor for some air horns.
What am I missing? (I was going to ask if I was crazy, but I knew the flood that would come with that).
And while I have your attention, oh wise electrical ones, different question for my shop. if I take a 110 VAC circuit to a motor, and convert it to a 220 VAC single phase circuit, does that cut the cost of my electricity? I know it cuts the amps in half, but does it cut the electrical charge ($) for that unit in half?
Yes, they will both carry 30 amps. If you were going to run it on a circuit that was constantly pulling higher amps, I would say go with the maxi fuse instead on the ATC/ATO style on the left. But if it’s just an air horns, you’ll be fine based off duty cycle.
International had an issue on the 40 amp ATC style injector driver module fuse in the DT466s. They would draw right at about 37-39 amps and overtime it would melt the fuse and holder. Turns out, the standard contacts on the fuse holder and ATC fuse couldn’t really handle the constant 35+ amps, even though it was a 40 amp fuse. The tabs would start to warm up and pull away from the fuse, making everything even hotter. Then you’d get a no start road call for a melted fuse and holder. They solved it by switching out the harness to a different alloy on the connector at the fuse. We solved it by replacing the ATC fuses with maxi fuses.
Thank you
I just put a 235 under my 87. I think that little tubular frame with the fold down bar is the same as on my 97, so it should be the same on yours. The 235 will fit in that frame with one exception. It’s snug, but it will fit.
If it’s like mine, it has a bolt that faces the rear. When you take the bolt out, there’s a little L-shaped bracket that hooks under the main bar. You have to tilt that back to let the tire down. If you’ve got a receiver hitch under the truck, that little bracket won’t pull back far enough to release the main bar. I used a grinder with a cut off wheel and I cut off about an inch or inch and a half of the tongue on that L bracket. There’s still enough left to catch the bar so you don’t have to hold the tire up while you try to thread the bolt.
Hope it helps
Thanks. That sounds like what I have save for a receiver hitch. I think I have a bolt for the carrier somewhere, but permanently storing it under there would first require finding that bolt. The original owner had it held up with a padlock and a wire rope that I had to cut. The guy I bought it from last spring had owned it since 1999 and didn't know that there was a padlock until I crawled under and then asked if he had the key.
For now I have it under my camper shell, which will be lockable as soon as I get around to cutting the latch bolts down so they don't stop the handle from turning all the way.
For your last electrical question, my understanding is that watt-hours are watt-hours. Potential efficiency differences aside, if you double the voltage and halve the amperage that should work out to the same wattage and therefore the same cost.
If it helps at all I think the bolt is just a 1/2" or 12mm, if it's 12mm it could be tapped to 1/2" easy enough and both will take the stock lug wrench to remove (3/4" hex). As far as the having a receiver hitch that GREATLY depends on which of the 5429 (+/- 6) receiver options are installed, I keep forgetting to look at my '97 but I just have the generic $50 Curt hitch on mine but I think the spare comes out... should check one of these days...
As for what I've done to my Ranger today, it's dumb... my '97's been loosing coolant for a while and I was under the hood looking at something for someone here so I investigated... saw the thermostat gasket wet so thought I found it then found the heater return hose resting on one runner of the exhaust manifold! It was just starting to seep until I touched it... I tried rednecking it with a piece of 3/4" hose slit and held on with 3 hose clamps but that made it worse... then I wandered the garage for anything that might be 5/8" OD tube wise, ended up spotting an empty CO2 cartridge for a pellet gun, checked and it was about 11/16" OD so close enough! Cut both ends off and deburred in and out and grabbed some hose pinchers and cutter and it's now fixed!
