Need HELP!
Looks like the short term fuel trim is almost maxed out in the negative. That would imply the egnine is getting fuel from somewhere other than the regular injector function or that air is heavily restricted.
Maybe a faulty or too large of an injector? They they said they were OEM, Denso not Motorcraft. Or not getting enough air to it. I've done a smoke test as well and can't find any leaks.
cylinder 1,2,3 look normal. 4,5,6 are really fouled.
that definitely means you have a problem with bank 2, the drivers side.
swap the O2 sensors between sides. look at the wiring.
or something is shorting those 3 injectors to ground.
try unplugging the 02 sensors, what happens?
try unplugging those 3 injectors and start the engine. it will run horrible but should not smoke.
last but not least, double check the plug wire order. look at the markings on the coil pack.
O2 sensors were changed just after I got that data, the old ended up throwing a code for stuck rich. I'll record another set today. And if you still think unplugging or swapping them over. I'll do that.
I'll unplug bank 2 injectors and let y'all know what it does. Not getting any circuit fault codes on injectors. But I'll check the harness with a multimeter and see if I can find any shorts.
Oh, and plug order on coil from front of engine to back is 1,5 2,6 3,4
another long shot, I mean a really ridiculous na' that can't possibly be it long shot....
is the driver side valve cover filling with oil? not draining back to the pan? pull the PCV valve and have a rag handy.
along that path of brainstorming, valve seals? unlikely, but an oil-flooded head will leak oil past good seals.
hey, at least this stuff is cheap to check.
yes, excess oil should also drain back thru the pushrod holes, but they are higher than the drain holes so quite a bit
of oil can accumulate if the drain holes are blocked. your plug 6 is the worst, it's also the lowest.
side note: cat converts can't differentiate between excess oil or gas. in their view both are fuel and the PCM will do strange things
to the fuel trim while oil is overwhelming the system.
again, all this is a lonnnnng shot but it's worth looking at.
So far, I attempted unplugging Bank 2 injectors. Truck doesn't even try to run without adding throttle. Too difficult to keep running and watch for smoke.
I did recheck fuel pressure KOEO= 60psi and KOER= 64psi Now, I don't know how much ambient temps come in to effect on pressure. When originally I got 44psi and 50psi.
Pulled PCV valve and it looks ok, and it is functioning. Doesn't seem like excess oil coming through. I suppose i can pull the valve cover to verify.
As for valve seats, I think they're good. Heads were replaced and compression test after showed 160psi +/-4 across all 6 cylinders.
look in the PCV hole for oil when its smoking. Helpful Hint: a moving rocker arm will quickly chew up any finger that gets in it's way.
the PCV allows the intake to suck fumes out of the valve cover, if oil gets in the way it gets sucked up too.
valve seals, not seats.
if the heads are loading up with oil the seals will become submerged and pass oil. no effect on compression.
again, the possibility of an oil issue is a long shot.
So I pulled the valve cover off bank 2. Mainly because I'm starting to doubt my mechanical abilities🤣 But in all seriousness i wanted to verify i didnt drop a push rod. No oil spilled out or was pooled. The valve cover has a splash block inside so I didn't see any spray, but I do think oil is an issue, at least partly. It seems to be in the intake manifold again. I just cleaned it last week when I swapped injectors. But there is residual oil on the mating flange of the lower intake (pictured) and I also noticed it dripping out of the break booster hose just now when it was disconnected.
No sign of coolant in oil either, mentioning this because the smoke is getting more white with the more it runs. Oil was dark brown black. Oil change will be done once its running.
  • Need HELP!
  • Need HELP!
Well, she may be done! It won't let me attach the video. But now there is a severe knock on bank 1, sounds like cyl 1. Again, pulled valve covers and valve train is good
