2002 Cruise control sparking sound under load
Jackson
TN - USA
Vehicle
Drive
Howdy, First post. I've searched all ranger & explorer forums, and I haven't been able to find anyone with the same issue. (I also posted this a couple other places if you see it anywhere else)
Some background: I bought a 2002 4.0 4x4 Ranger from an older fellow a few months ago, and I've been slowly clearing codes & making repairs. The truck is 100% now, but I've discovered a weird issue: when I'm using the cruise control and go uphill/under load, and noticeable arcing/sparking sound can be heard behind the dash in the direction of the fuse panel or the power distribution box . I considered speaker static, but it distinctly sounds like wiring sparking/popping. I can't hear it on flat ground, and the cruise control seems to otherwise work perfectly fine. The cruise brake pressure recall had been completed, but I went ahead and replaced it with the updated model switch anyways. All fuses look fine too. Short of ripping out the dash, I'm at a loss. I really don't want to use the cruise either until it's fixed.
Has anyone had a similar issue, or would anyone have any ideas of what I could be? I can give any additional info/videos if need be. Appreciate it.
I would use it sparingly until you get it sorted out.
I would almost pull the fuse or somehow disable it honestly.
I've been avoiding using it. Pulling the fuse isn't a bad idea either.
I've read that wonky clock springs can cause noises, but I don't know. If I could track down a cruise control wiring diagram for my year/engine, I feel like I'd have somewhere to start. Not having much luck though.
Check ebay for a 2002 Ranger EVTM, I used the appropriate one to retrofit OEM cruise to my '85.
Appreciate it. I'll look, but I still might end up taking it to the stealership and see of some old tech has an idea.
I'd be happy to avoid that though if anyone has any other ideas...
