1 Ton YJ Crawler build
I don't know much about Jeeps but I do know fuel systems... Does the rail have a return out of one end and supply on the other with a regulator on the rail? That's the BEST setup for vapor lock assuming the fuel pump is in the tank, if it's not it needs to be as close to the tank as possible and as low as possible. If external pump and only a single pump system it's best to get a low pressure pump to put first in line (the marine Carter/Sierra is a good one, or as good as you'll get). You want to get liquid fuel through the fuel rail and flushed out so it can cool off. The heat shield and louvers should help your situation though.
Yeah, the 4.0 was basically designed for vapor lock. Fuel pump is in my fuel cell, but the fuel rail sits directly next to the valve cover and above the exhaust manifold. Combine that with what I think was a sticky thermostat so that it was running a little hot and the temps were wild. Water was cooking off the fuel rail
Love having a hoist. New rear main seal became a 5 minute job
  • 1 Ton YJ Crawler build
Threw some paint on the block while it was off the stand
Have my fancy oil baffle coming this week, and got the Holley oil pan fitted in. I will have to drill out one hole to mount it - it always cracks me up how "every of X motor is the same" rarely pans out in practice. There's a bolt hole that wasn't used in my block with the stock pan I guess
My steering box is probably done. The cap has a hairline crack from hitting a rock with it. There's a snap ring that holds it on, hoping I can find the part number for that and the cap and just replace those. I don't really want to spend the money on going full hydro, but also don't want to put any money into hydro assist. Not sure what I'm going to do yet
Started debating selling my 4 speed atlas to go to a 2 speed. I don't use the underdrive, it's just too low.
Have headers on the way. Going to start ordering sensors and the water pump, though I'm not sure about accessories yet. Likely to use one of the goatbilt brackets, but I need to decide about my steering stuff before I go wild there
From one of the black trails early at AOAA. Broke the jeep on SOB when I started screwing around because the guy in front of me was stuck
Oil pan is on. I cant for the life of me find the dipstick I was sure that I had from my buggy, so I guess I'll order that. Today I'll throw the harmonic balancer on, and I think next will be sensor replacement? Not sure yet.
I've given up on trying to get a TH400 locally - everything is either complete toast or a high dollar drag application. Going to go 4L60e or 4L65E and call it a day. The 4L80 is just too long for my application
Isn't the dip stick behind the steering wheel?
ahhhhhh....misread your kirby post did i....
Yeah, my jeep is set up for west coast high traction stuff, not wheel speed. low low low isn't really needed for me
Starting to pull this thing apart. Had to get some spacers for my coils on the motor, but once I have those it'll be as together as its going to get for a while.
Pulling driveline, draining fluids first. Then I'll probably pull the Atlas and maybe take it to my buddy's shop to have him change the input for a GM and generally freshen it up.
Couple of things I haven't made decisions on yet - crossmembers and skids. I don't like my aluminum skid, but also don't want to redo everything. Also need to decide on accessory brackets for the motor, leaning towards the goatbuilt that relocates the alternator up
Now the real work starts
