Wallers in rivers
💻 TRS Socials
- Aug 7, 2007
- Frankfort
- State - Country
- IA- USA
- 5.0L
Current Setup for a carb:
Low pressure in tank fuel pump (say for an '86)
Non-return fuel pressure regulator at intake manifold.
EFI system I would like to go to needs like 43PSI so the hodge podge borderline mess of factory 6mm nylon fuel line, brass fittings, hose and clamps will not work. I would like to upgrade anyway.
EFI will be a throttle body style. Will need a return style regulator.
Any pointers on what kind of fuel line/fittings to use? What works well what doesn't etc?
Kinda torn on fuel pumps, being a long distance driver I like the option of falling back to a carb if the EFI bricks itself. Run two pumps like a '86? Then if I needed to carb swap in BFE I could just bypass the high pressure pump. I used to have a red Holley pump on the frame rail, it was a PITA to prime so I like the thought of an in-tank pump either way. And if the high pressure pump dies I wouldn't have to drop the tank to replace.
The system will be feeding my carb for the time being, when the time comes to install the EFI I will replace the regulator, pump(s) and add the return line.
Thread on how I arrived here:
Mulling going to the Explorer EFI setup, interested in what works for air cleaners. Preferably a OE style box not just an open element.
Also did you use OE style electronics, megasquirt or?
- 85_Ranger4x4
- Forum: Engine Swaps & Forced Induction
